Engine wont turn over
Hi, i posted this on another site also but i wanted to see if anyone here would have any ideas to my problem. Ok heres what happened. Last week i was driving it hard and the engine started making a ticking noise. I got home and took off the valve cover and a polylock nut had broken in half leaving one rocker really loose. So i bought a new set of nuts and while i had it apart i decided to check all the valves. Now im reinstalling everything and the engine wont turn over. The car was running before i shut it off. After a few full cranks with the wrench it just stops like somthing is binding. Anyone have any ideas?
It wont crank, spark plugs, rockers, pushrods, belts, are all off.
I put an extendable magnet in the spark plug hole, nothing in there.
Can you put a wrench on it and turn it backwards? the engine that is. On the harmonic balancer. Maybe an issue with a piece of the valve? I know you said you checked it with a magnet but possibly in another hole? perhaps pulling intake and heads would be a good idea.
Yea i got a hold of my uncle whose a ford mechanic and he was telling me that hes 95% sure its a bent/broken valve. Some people on another site think its a bent valve also mouse. The heads are coming off tomorrow then. Its a learning experience i suppose. Ive never been into an engine so i might as well go for it. Hopefully it isnt too bad :notnice:
Shouldn't be to bad. As long as it didn't mess up the valve seat. Then you will have to take the heads down and have a seat put in. I bent five when i blew my motor up the other month.
What all do you got done to the motor?
WAS IT AN EXHAUST POLY-LOCK?
LONNNNNGGGG REPLY AHEAD!!!!!!!.......................
i have been trying to think of an answer to this question off and on for a few hours now and i read it for the 5th time a second ago and came up with this. i think you might have done exactly what i did on my 306. i was at the track (obviously i was givin it hell) and i heard a tick then felt a miss, so i shut down the engine and coasted to the time slip booth and got my slip and refired the engine to baby it back to the trailer. i pulled the vc and saw that i had bent a push-rod on the exhaust. soo i drive to summit in atlanta on saturday and get a new set of pushrods. install them. on inital install i heard a slight tick/knock for just a second and then it went away so i figured it was just nothing. the engine ran fine. so i go back to the track for test and tune on sunday. i ran like 3 passes and came home and pulled the engine to install forged pistons and freshen the motor.(unrelated to the pushrod incident) when i pulled the engine down the connecting rod on the cylinder that had bent the pushrod was bent!!! the slight tick/knock was the rod hiting the counterweight on the crank. the ticking/knocking went away because the crank shaved just enough off the rod as it passed to make it clear without hiting anymore so the engine was quiet and i didnt know what had actually happened. i would be highly inclined to think this (in some form/fashon) has happened to your engine.
P.S. i had EAGLE I-beam rods!
IF IT WAS AN EXHAUST POLY LOCK THIS IS MY GUESS!!!
You got any pics of this?
Valve isn't stronger than the con. rod.
When this all happened...you were able to drive the car home right? How bad was the ticking and where did it come from? I bet what happened is that you bent a valve (hit the piston) it broke your poly lock. You may have gotten lucky (or unlucky) enough that the bent valve hung up closed. Either way at this point that valve wasnt functioning at all so the motor could turn over. The pushrod would move the rocker..but the rocker wouldnt/couldnt move the valve. Now that you have it all back together...thats where its binding up. The valve is probably bent/stuck up in the valve guide.
Try this...take the rocker off of that valve and try to turn the motor over...it should spin. If not you probably have a more serious bottom end problem. Tear it down man.
that makes sense too. u r going to have to take it apart.
what happens when the exhaust wont open at high rpm's is the burnt gasses cant get out and after the plug fires, it goes down on power stroke, and then back up to push out the exhaust but the valve is not open, so the pressure is very very high because the air fuel mixture has expanded and is too much for the rod to compress so the rod bends a bit.
i have broken a rocker on the exhaust and this not happen
but i have had it happen also.
i dunno im just sayn:shrug:
TAKE IT APART TODAY!!!WE WANT PICS TONIGHT!!!!!
I tried to crank the engine over with no rockers or pushrods so maybe the valve is really messed up in there? I have no idea.
The engine is a 347 stroker, crane 1.6 rr, edelbrock heads/intake, probe pistons, Eagles rods (i beleive), along with everything else that could possibly be done. I bought the car the way it is so im still learning.
my old engine builder was off by like 3 teeth on the timing chain with the dot to dot and i didnt know until i tore it down after a no start. i ended up bending all 8 exhaust pushrods thanks to this numb nuts. and just yesterday when the machinist went to cut the valves (engine is at the machine shop getting goodies) i found out all 8 of my exhaust valves were bent. :notnice:
just out of curiousity, are all of your plugs out when you try to turn the engine? that would be enough to give you trouble turning it
ok all sparkplugs, all rockers, all pushrods, all belts are off. It still will stop.
I didn't have time to do the heads tonight they will be done tomorrow. when i drove it home it wasn't bad, it was kind of a soft ticking. The sound wasn't as if pieces of metal were hitting.
When I take off the heads tomorrow, where do I drain the coolant from to get it all out? Is there a drain plug on the engine where I can get to it?
when you say check all the valves what does that mean?? did you possibly tighten any of the polly locks???? this may be causing the valve of the tightend polly lock to be hitting the piston. also check the plugs for any nicks or funny out of place marks. do you know any one who has one of those cheap boroscope tools. if so take a look inside. ( the tool is about 200 bucks) chris
I took everything off to check the pushrods and make sure that all the poly locks were on there tightly. I thought I might as well while im in there. I have EVERYTHING off of the engine so all the valves are closed and its still binding somewhere.
