first gear, 2.84:1, second gear, 1.55:1, third gear, 1.00:1, overdrive, 0.70:1
Builds boost in first gear at the shift 6200rpm
Second gear I finally hear the gate open at 4500rpm
This is why I want to gear it up more by the time im into boost its time to lift
I can control all aspects of the shift points and I already pull 6* of timing during the shift so it does not shake the tires. [and helps to not make the trans explode] I use RPM based upshifting at WOT
and don't forget...Enola spelled backwards is Alone....maybe its a sign?
