Build Thread Enola- Finishing touches
  • Thread starter Thread starter a91what
  • Start date Start date May 31, 2015
  • Tags Tags
    393 4r70w megasquirt ms3 ms3pro turbo watermeth injection
  • 21
  • 22
  • 23
  • 24
  • 25
  • 239
First Prev 23 of 239 Next Last
hoopty5.0
mechanicus terribilis
7,813
6,968
214
SW Houston
Feb 2, 2016
#441
  • Feb 2, 2016
  • #441
That's a level of science well above my pay grade.
Reactions: stang89bidges, A5literMan and a91what
Bullitt347
I have been doing it wrong this whole time
4,017
3,011
204
Middle of Maine
Feb 2, 2016
#442
  • Feb 2, 2016
  • #442
a91what said:
Does anyone know what effect plenum volume has on an engine? I don't mean for power output I mean for wave reversion......
It seems from some reading that a larger plenum volume causes the air to "slow down" so to speak. So the pressure drop when a cylinder opens causes a back wave that aggregates the issue. Essentially I have created a massive plenum (11ft of 3" pipe + huge IC + cobra intake) I was wondering if some of you smarter than me guys can help here. Or if I can put in a short path bypass so the tb feeds the plenum almost directly when in idle conditions, otherwise I am gonna tear all this new **** out and put both tb back on...
Your overthinking this. It should not matter. In a N/A application you may have a point. And the only time this is N/A is idle, cruise and deceleration. Move your base idle speed up a bit and any surge should go away. You can also fatten up the idle circuit as well. What you are getting is called compressor surge, which is typical in positive displacement S/C applications. A larger by-pass valve may help. If you can, bypass from the cold side to the inlet.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 2, 2016
#443
  • Feb 2, 2016
  • #443
I am certain it's not compressor surge, I put on a shorter belt so the SC is not spinning and have my bypass opened with a vacuum pump. The car won't idle down past 1300rpm afr of 13.6......
I will try the bypass from the tb to cold side.
Bullitt347
4,017
3,011
204
Middle of Maine
Feb 2, 2016
#444
  • Feb 2, 2016
  • #444
If it still has an IAC valve, that could need some cleaning or replacement. Either that or your Mega whatever engine management system is not set up right.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 2, 2016
#445
  • Feb 2, 2016
  • #445
I ask is brand new and idle just fine before I move the throttle body. This is also with the IAC unplugged setting idol with a FRPP idle control plate
Bullitt347
4,017
3,011
204
Middle of Maine
Feb 2, 2016
#446
  • Feb 2, 2016
  • #446
Then you have an air leak or it is programmed wrong
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 2, 2016
#447
  • Feb 2, 2016
  • #447
Now I mean no offense but the tune is fine, will it need tweeking yes but the car should idle.
Now after looking at some pictures of cars with similar setups (supercoupe) they positioned the bypass so that air when in vacuum only has 1ft of travel or so to reach the plenum not 8ft +Ic. So my test today will be to put in a short path bypass.
hoopty5.0
7,813
6,968
214
SW Houston
Feb 2, 2016
#448
  • Feb 2, 2016
  • #448
You're running it as speed density, right?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 2, 2016
#449
  • Feb 2, 2016
  • #449
Yup.
Oh and I think I found the problem too..... I forgot that the bypass was originally intended to blow off excess pressure (the up stream to was opened farther that the one at the plenum.)
Soooo guess which tubes are still flexible and crush under vaccum?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 2, 2016
#450
  • Feb 2, 2016
  • #450
a91what said:
Yup.
I just removed the SC and bypass out of the equation all together to test this. Same issue, lots of frustration. Lol.
So I am putting the tb back on the plenum until I get a different bypass worked out. I am going to reseal the SC while I am at it. One step forward two back.
95BlueStallion
My assy trans to myself
5,129
3,100
214
Cedar Rapids, Iowa
Feb 2, 2016
#451
  • Feb 2, 2016
  • #451
I tell you what, if the thing ran really well with two throttle bodies, so be it. Its home made, so it doesnt have to model anyone's kit. Whatever works and makes it run well so you can enjoy it is what I would roll with.
Reactions: A5literMan and 2000xp8
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 2, 2016
#452
  • Feb 2, 2016
  • #452
I do agree with you there! I am going to roll na for a bit and get those tune areas dialed in better.
I was just hoping for less of a "cobbled together" look....
It does work but man its fugly
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
Feb 2, 2016
#453
  • Feb 2, 2016
  • #453
Well, had you shelled out a bunch of cash to a shop to fab up a kit, then yeah it would be fair to worry about the overall look. But being you have made it out of scratch, for pennies on the dollar compared to supercharger kits, it works! On the flip side, some folks like @madmike1157 clearly get more enjoyment out of the build than the finished product, so maybe you enjoy sorting out the issues that come with refining your creation. Either way, its a really cool thing youve done with your car.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 2, 2016
#454
  • Feb 2, 2016
  • #454
Thanks!
I would take more time on these things but having the car ripped apart is difficult. As I have no shop or even a garage for that matter. All of this is done in the yard, out of a tool shed....
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 3, 2016
#455
  • Feb 3, 2016
  • #455
OK so I ruled out tune (for now) and mechanical issues.
Put the tb on the plenum and without adjusting anything she started up and idled at 800rpm cold.
Hmm I don't know, lol.
I think the issue IS the bypass from tb to cold side. I also have some ideas beating around my head about using meth and deleting the ic..... it involves flipping the plenum and reworking the SC inlet.
HA! I can never leave well enough alone.
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
Feb 3, 2016
#456
  • Feb 3, 2016
  • #456
Well, you just lost my sympathy, lol. But either way, I enjoy your project, so go for it!
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 3, 2016
#457
  • Feb 3, 2016
  • #457
Lol. Naw I'm gonna just get it figured out the way it is now. I will be making a new SC inlet however, I may as well its going to be on the workbench anyway. If I got rid of the strut tower brace I could open up a lot of options.
How much rigidity do you think that brace adds? Would it be worth pulling off?
2000xp8
SN Certified Technician
Aug 8, 2003
8,058
1,643
194
NJ
Feb 3, 2016
#458
  • Feb 3, 2016
  • #458
You will be fine without it.
Reactions: A5literMan and a91what
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 3, 2016
#459
  • Feb 3, 2016
  • #459
I like that answer! The STB comes off and a new inlet with the TB being fed from the driver fender goes in. Then I will build a bypass tube between the new inlet and the cold side to test for idle issues (before I buy the relatively expensive mini cooper bypass) should look and perform better....
Then I drag out the oven from behind the shed I use to powder coat stuff.
stang89bidges
Advanced Member
Mar 14, 2014
727
144
74
Fort Worth Texas
Feb 5, 2016
#460
  • Feb 5, 2016
  • #460
Finally. Proper routing lol. I will be
Reactions: a91what
  • 21
  • 22
  • 23
  • 24
  • 25
  • 239
T
TJ's Eaton M90 Build-Up Thread
  • tjh566
  • Jan 8, 2007
  • 1994 - 1995 Specific Tech
  • 3 4 5
30K
1994 - 1995 Specific Tech Oct 15, 2007
RAD
R
