Build Thread Enola- Finishing touches
Can you document that setup of this as this my be something to put on the todo list as well.
I plan to document the building of the mods and since I have my work PC to use I plan on doing a screen recording of the retune process start to finish. Including output tests ect.
I just have to make sure my work PC has a program that will do the recording, I believe power point can do it.
Just got off the phone with Jeramiah at BullFrog perf. my total estimated cost to clean freeze plug bore block ect, turn the crank, balance the assembly, surface the block, turn the toothed wheel and order my ts1 piston rings from total seal
$850+ the cost of any bits he breaks turning the wheel. I should be able to pickup sometime next week.
Stop bannana time. :banana:
The Snipping Tool in Windows 7 or later will capture any screen shots you need. Then you can paste them in Microsoft Word or WordPad. Every Windows computer has some version of WordPad as standard equipment. Microsoft Office (Word, PowerPoint, Excel, etc.) Is something else you usually end up paying for.
If you have any questions about Windows or Microsoft Office, ask me. Fixing computers & computer software is what I do for a living...
Cool i want to do a full screen recording with voice over from a headset so i can tune in real time with the car running. I have a full paid version of office.
PowerPoint will do that without much difficulty. You can insert video clips with sound as individual PowerPoint slides. Then you convert the whole PowerPoint presentation to a WMV or MP4 file.
Or you can use Widows Movie Maker, but editing the sound when it is live on the video stream will not be simple.
I advise you to do the video and the audio separately. That way the audio can be edited to remove the flubs and mistakes.
First, write a script for what the video is doing. That way you will be able to include all the important points you want to cover and not miss anything.
Shoot the video, and edit it.
Read and record the script , edit the audio and then sync up the video and audio so that they match.
The audio editing software is a free, open source download - See https://www.fosshub.com/Audacity.html/audacity-win-2.2.2.exe. It has somewhat of a leaning curve, but once you get started, it works very well.
  • Useful
Reactions: a91what
I think I am going to make a new inlet plenum for the build, I honestly think what I built the first time is wayyyyyy to much. I want more subdued this time, I just dont want to buy a damn $400 TB.... the whole point of using 2 was to cut cost.
I also need a real catch can and lines to finish it up...
All the required parts arrived today to rebuild the eaton m112.... so whaddya think I did after work?
I would have guessed wrong. :(
