I remember reading somewhere that heat ( as it relates to an exhaust system) is a necessary evil when turbos are in the mix. A hot turbo moves air more efficiently as compared to a cold one.I cant help autocorrect gets it wrong every time.
NO.. actually the turbos dont even get hot enough to feel any heat through the turbo blankets.. also NO. I dont want to do it like everyone else does let them live in the sea of sameness
Yes, however in practice a smaller exhaust housing will alleviate this issue. Cooler gasses have less volume.I remember reading somewhere that heat ( as it relates to an exhaust system) is a necessary evil when turbos are in the mix. A hot turbo moves air more efficiently as compared to a cold one.
Specifically….
In general, turbochargers should be placed in the hottest areas of an engine bay as turbine efficiency is proportional to the kinetic energy of the incoming air to the turbocharger fins. So the hotter the air, the better.
The Pros & Cons Of Rear-Mounted Turbos | TD Blog
Doctors did mention they saw something. Not sure if it was turbo.Remember, I have tinnitus, that's like a small turbo in my head
Funny, the doctors told me they couldn't see anythingDoctors did mention they saw something. Not sure if it was turbo.![]()
we need angrier emojis
woo banana time. This means I need to find some much larger filters for the turbos
Congratulations, you now have a soleless robot shifting the trans.I spent a few hours on Sunday trying to get the damn transmission to function properly.. sometimes it would shift and other times it would not, very frustrating to the point I was ready to set it all on fire and drink beer.
Nothing seemed wrong... I finally gave up and decided to try something new, I removed the MSGPIO board I built in favor of a cased V3 Microsquirt running the same trans code. This did require that I completely repin the trans harness. As soon as we leave the driveway [pop driving me at the keyboard] it shifts into second, then third, then OD... MUTHRFUGR this GPIO bench tested fine but would/could not drive the solenoids I likely had a perfectly good transmission the first time.....we need angrier emojis
Now to the turbo issue...
I wired in an alarm to tell me if the oil was backing up at the scavenger pump then I went and drove the car around a bit on the dealer tag, I never got the alarm so I know the pump is able to keep up with the system easily enough. The first trip with the filters on got oil in the system, I simply pulled the filters and cleaned the pipes out for the next few drives, I have not gotten out their yet to see if they have oil in them.
The transmission tail shaft is leaking badly, I think they removed the AOD bushing and seal and put in a 4R bushing and seal.. just my luck, I am using an AOD yoke so its leaking enough that I had smoking exhaust and a puddle under the car. Nope the tailshaft is for an AOD. see reply below
Thank you!! I have the option of clicking it into manual mode and taking full control of the shifting anytime I like.Congratulations, you now have a soleless robot shifting the trans.
The coil over kit was left alone from when it was the 302, with the extra weight of the 351 and the k member swap I need to raise the car.Damn that's low man. The import guys would love that. I used upr coilovers on Monroe struts to raise my front end about 1.5. The driveway liked kissing my bumper.
Uhhhh air shocks?The coil over kit was left alone from when it was the 302, with the extra weight of the 351 and the k member swap I need to raise the car.
Raising the front means I need to raise the rear as well... I don't have coil overs in the back, any thoughts on how to achieve this?
Not if the car will look half retarded like this exampleUhhhh air shocks?
Beauty is in the eye of the beholder.Not if the car will look half retarded like this example
Thanks Mike this has been helpful.Beauty is in the eye of the beholder.
Besides, they don’t even make air shocks anymore.
Sorry.
