equal length shorty header removal
sacky07
35
how the heck do you get an equal length shorty header out of the passenger side of the car?! It seems like that one AC line is in the way. I dont think removing the h-pipe will help either. Would a set of regulay shorties be a little smaller than the equal length? I have turned this header every which way but loose and it still aint coming out. Any tips?
take the h-pipe off, loosen the motor mounts, leave the nut on just a little bit on the opposite side of the header you want to remove and jack the motor up with a block of wood under the oil pan. It should slide out easy. Equal lengths are much easier to work with
Yeah unhook the H and unbolt the motor mounts from the frame. Once the mounts are undone you can push the engine from side to side a bit for more clearance. I don't have A/C lines anymore so mine just go in and out on the topside. You might have to remove them from the bottom if A/C line is in the way and not flexible enough.
