  • SN95 4.6L Mustang Tech
Equal length Shorty Headers Worth the Trouble?
  • Thread starter Thread starter ToplessStang
  • Start date Start date Jan 29, 2006
ToplessStang
591
Montreal, Canada
Jan 29, 2006
  • Jan 29, 2006
I currently have O/R Prochamber and MagnaFlow Cat-Back, would I see any significant gains with BBK equal length shorties? Worth the trouble of the install? I know most say regular shorties aren't worth it but I assume the equal lengths perform a little better.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Jan 29, 2006
  • Jan 29, 2006
no
only consider shortie IF you have to worry about emmission test. Otherwise, amount of work needed to install headers in our car, Its just not worth the trouble. It'll be like most expensive 5hp you ever going to get.
blackfang
1,290
Richmond, Va
Jan 29, 2006
  • Jan 29, 2006
Longtubes will give you alot bigger gains down low and midrange. Peak is around 20 rwhp
Sonicpony
92
Mooresville, NC
Jan 29, 2006
  • Jan 29, 2006
not worth the trouble! mabe only if the engine was already out of the car..
and u got them on the cheap!
stangGT97
1,299
Boston area, MA
Jan 29, 2006
  • Jan 29, 2006
if you're bent on keeping your current mid pipe, I guess the shorties would be OK. I played around with the idea for a while, I'll probably do shorties if I end up doing the PI headswap bc the heads will be out of the car already. If I have extra cash then I would definitely get the LTs and a shorty mid pipe
ToplessStang
591
Montreal, Canada
Jan 29, 2006
  • Jan 29, 2006
Two reasons why I can't do the LT's. My mid pipe and my H&R drop. The way this thread is going, it looks like I saved myself some money AND work. Thanks guys .
stangGT97
1,299
Boston area, MA
Jan 29, 2006
  • Jan 29, 2006
yea man just keep your manifolds
billfisher
1,296
huntsville, AL
Jan 29, 2006
  • Jan 29, 2006
shories make power from lowering restriction not from tuning. any short tube. unequal length is the same. and easier to install.
longtube is the only type that tunes pulses. and they need to be fooled with for max hp. if you want all hp
longtube with 3" collectors, 3" extensions with 45 degree bend and 4" supertrapps exiting under the doors.
tune the supertrapps for torque. hard to beat.
edit: \/ \/ \/ right. unless your after ever stinkin hp just do what is easy.
W
WOT
2,817
Regina, Canada
Jan 29, 2006
  • Jan 29, 2006
IF you are going blown it really won't matter. They only differ by 10-15 hp on the top.
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
