I have a 90 coupe that i recently purchased. The guy had done 4cyc to a 5.0 swap with A9L and 90 harness. I have preformed all the trouble shooting steps that were in earlier post. I have correct voltage and ohm readings and even swap Bap sensor with good one from another car and can not clear code 22. Also dump codes and it is always there. Car idles fine and when it gets to around 3000 rpms it stumbles, stalls and backfires and no power.
He has also rewired the fuel pump relay and it constantly runs with key in the on position and I'm getting error code 87. Didn't know if I should rewire it correctly and replace the wiring? I also installed a 225 lph fuel pump and Kirban FPR and can not get fuel pressure set under 45 psi, it doesn't change with or without vacuum?
