I spent a few hours researching on 4M.net and I think I have the solution for using the Escort Flywheel in a 2.3 Mustang.
Parts needed: Escort GT flywheel ('80's 1.9L) and bolts. Mustang disc,pressure plate.
Here's where it gets a little tricky.Throw-out bearing.
option1: use the Mustang t.o.b. and stack 2-3 thick washers under the clutch fork pivot ball.
or
option 2: Use a t.o.b. from a '60's Chevy I-6 (10" clutch)
The mini-stock guys run this all the time and concensus is it will be good on the street for a NA car.
Turbo apps. will need a bigger clutch set-up.
HTH and try at your own risk,yada yada yada!
or
