everything needed to use fox throttle body
I believe fox headers will bolt up, but they don't have the EGR bung on the passenger header. If you're eliminating your EGR you should be good to go.
Dunno about the fox throttle body, sorry.
YOU NEED:
fox TB
fox tb cable
throttle cacle bracket
EGR valve and spacer (only a 3/8" spacer is needed if your eliminating the EGR)
fox injector harness ( for the plug needed to plug in thr IAC valve)
splice plug for the IAC valve
fox CAI
If you search there is also a how-to around here I believe.
