There have been a lot of misconceptions about gears floating around, and I would like to provide what knowledge I have about them.
First, changing to something like a 4.10 gear does indeed increase torque at the rear wheels, but as a consequence the rate/speed/rpm that this force/torque can be applied at decreases by the same ratio. If the torque multiplication goes up 10%, then the speed for that given torque goes down 10%. This is a physical law of gear trains. Also, the overall power to the rear wheels is the same (this is not exactly true, but it will be covered later) since you have not actually done anything to the engine to make more power. So, you can also look at it like this:
Power = Torque*RPM/5252
If the power must stay the same
RPM = Power*5252/Torque
RPM = (constant value) /Torque
Then as the torque goes up, then RPM goes down.
Now that means that adding gears will not make your car faster over a given distance if you only use ONE gear. You maybe able to accelerate fast at first, but you cannot go as fast so in the end you cover the same distance in the same time.
However, when multiple gears are used, such as provide by the transmission, then you can go faster. The reason why is that you can think about the power curve of an engine is shaped like a bell. When you only use one gear you only have the power output of this one curve over your entire distance you travel. You will start out low on power and increase in power until you hit your peak power, and then it will decrease again. The amount of power you use over the entire distance is not just the peak power, but it is the average power. That is why you always here about racers saying that peak power is not always that important. As you added more gears you can keep reusing this power curve multiple times, but at the cost of less torque due to the gearing. First gear will give you the torque to get the car accelerating, but the other gears help you obtain higher speeds. Now, you can average the power you used over the distance. As you use more gear ratios over the same distance your average power used actually increases. This is what makes your car faster with 4.10 gears. Instead of using 1st, 2nd, and 3rd gear in the quarter mile you are now also using 4th gear. More times through the engine’s power band means more average power used, and that means you can go faster.
Now that you understand on how gears actually make your car faster, then let me make a comment about the dyno. Your car’s engine is “basically” making the same amount of power no matter what gear ratio you run. The fact that the dyno reads a different value with different gears is due to how the power is measured. You are not directly measuring the engine’s power on the dyno, but you are instead measuring the power applied to the dyno or the rear wheel horse power (rwhp). There can be two causes for a lower rwhp reading. The most common loss of hp is due to drivetrain efficiency. This is how much power is used/lost due to the transmission and rearend gears. This power is used to basically overcome friction and usually shows up as heat, but is also a function of how much “slip” there is present in the drivetrain (i.e. clutches and converter). How much power is lost varies depending on the transmission type, gears types, and gear ratios. This is where you get the numbers of 15% (5 spd) and 20% (auto). Basically 15% of the power your engine produces is wasted to overcome friction in the gears, and simple gets transformed into heat. This is not really constant, but for this discussion it is easier to see it that way.
Now, when you switch to something like 4.10’s in the rear end it is noted that the dyno shows a loss in hp. Well, this is true and it really does have some to do with the drivetrain loss, but not all. You will loss a very small amount of power due to that lower gears are a little less efficient, but it is very little and not enough to worry about. Where the real power loss comes in is due to how much faster you car can accelerate the rear wheels. The power measured by a dyno is determined from drums acceleration, speed, and inertia:
Power = Torque*(Angular Velocity) => this is where hp= tq*rpm/5252 comes from.
Torque for a rotating system is calculated as: Torque = Inertia*(Angular Acceleration)
Thus, Power = Inertia*Acceleration*Velocity
P = I*A*V
However, this does not include the inertia of the car’s parts such as the driveline components (flywheel, clutch, transmission parts, rear end, driveshaft, wheels, etc). All these things are gong to require power to accelerate them also. Technically the equation would look something like this:
Power(dyno) = Power(engine) – Power(driveline)
Power(dyno) = Power(engine) – I(flywhl/cltch)*A(flywhl/cltch)*V(flywhl/cltch) – I(trans)*A(trans)*V(trans) – I(wheels)*A(wheels)*V(wheels) – etc.
So technically the dyno only measures velocity and acceleration not torque or power. The computer attached to the dyno calculates the torque and power using the known inertia of the dyno’s drums and an estimate of what you car’s driveline inertia.
This brings up a good point while I am here. One cannot take the result from the dyno as gospel to how much power you are making. The last bit about you car’s inertia is important. Depending on the values used in the computer’s calculation for you car’s inertia can affect the dyno’s reading, and it is different for every car and truck. Since it is impossible to measure all these values the dyno just uses an estimate. I have heard of some dyno operators using the wrong values to make it look like you have a little more power than you really do. However, in general the idea is that the dyno’s drum has an inertia that is much great than you car’s as to reduce the effects of the car’s driveline inertia on the power readings.
Ok, now to the part about different dyno readings in different gears. The reason that you will see lower power readings with lower gears (1st or 4.10’s) is because they accelerate the whole engine-driveline-drum system faster. For a simple example let’s look at changing from 3.27’s to 4.10’s dynoed 4th gear (1:1).
3.27
engine => 4000 rpm
trans => 4000 rpm
wheels => 4000/3.27 = 1223 rpm
4.10
engine => 4000 rpm
trans => 4000 rpm
wheels => 4000/4.10 = 976 rpm
Looking at the above we can see that changing from 3.27’s to 4.10’s decreased the wheels rpm by 247 rpm or 1.25%. Going by just the wheels’ rpm and gearing the power output should stay the same since the torque/acceleration went up by 1.25%, but the rpm/velocity went down by the same 1.25%.
The important difference is that the engine and transmission rpm is the same, yet they where accelerated faster as a result of the 4.10 gears. That is it took less time to get up to 4000 rpm with the 4.10’s then it did with the 3.27’s. This means that it takes more power to accelerate the engine and driveline components since the velocity is the same, but we have a higher acceleration (refer to the earlier power equation).
Example: P(dyno) = P(engine) – P(driveline)
3.27 => P(dyno old) = P(engine) - I*A*V
4.10 => P(dyno new) = P(engine) - I*{4.10/3.27}*A*V = P(engine) - {4.10/3.27}*I*A*V = P(engine) - 1.25*P(dyno old)
The change in the dyno or rwhp should look something like this:
Pwr(4.10) = Pwr(engine) – 1.25*Pwr(3.27)
Each part in the driveline system requires 1.25 times as much power to be accelerated when switching to the 4.10 gears. Thus the power seen at the dyno’s drum will reflect this loss.
I hope that helps. I can’t say everything I described is 100% correct (feel free to correct me if I am wrong), but to the best of my knowledge the above should be true.
Mike
P = I*A*V
3.27
engine => 4000 rpm
trans => 4000 rpm
4.10
engine => 4000 rpm
trans => 4000 rpm
Mike
informative post thanks!
