Exhaust size
  • Thread starter Thread starter Cobain03
  • Start date Start date May 1, 2006
1 of 2 Next Last
Cobain03
996
Lexington, Ky
May 1, 2006
  • May 1, 2006
i currently have 2 inch pipe comeing from my tri y's , headed toward dual 40 series flowmasters then out the back.
im thinking that 2 inch is probably too small. am i right? what am i loosing/gaining? with a different setup?
M
mustangman1974
463
  • May 1, 2006
depends on the engine power. but 2 in is good for 300-350 horse
iskwezm
4,159
20
79
Rowland Heights,California
May 1, 2006
  • May 1, 2006
I would NOT use 2", at the very least 2 1/4 or 2 1/2. IMO your choking it a little bit
Cobain03
996
Lexington, Ky
May 1, 2006
  • May 1, 2006
mustangman: my mods are in my sig.
im getting opposite responses here. i would coust abuot 180 to get the pipes re done. worth it?
19stang66
689
  • May 1, 2006
I bought that Flowmaster american thunder system and have it almost installed. I take it this Wednesday to a muffler shop to have them fab up pieces to complete it. I used to have manifolds and 2 inch pipe with cheapo mufflers. Now I got tri-ys with 2.5" pipe and 40 series 2 chamber delta flows. I can't wait to hear how she sounds!
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
May 1, 2006
  • May 1, 2006
I went 2.5" with flowmaster 40's...sounds great! 2" is probably OK, but 2.5" gives you a slightly deeper tone.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
May 2, 2006
  • May 2, 2006
At your power level, 2" is about right. It certainly wouldn't be worth the money to upgrade vs. power; I'd wait until the exhaust needs replacing and then go to 2 1/2".
R
REPLIMOD #17
52
  • May 2, 2006
It would be nice if somebody did some dyno time with cars of different hosepower levels to see what size tubing was best suited to a certain HP range.
For example:
2" 150-200Hp
2.5" 200-375Hp
3" 375-550Hp
Is anybody aware of such a chart, Or are my numbers a close enough guess?
zookeeper
3,415
63
109
Rogue River, Oregon
May 2, 2006
  • May 2, 2006
I agree, it seems that everyone has their own opinions, and that's what they are-opinions. I think 2" is likely just fine for a mild small block street car, but I don't have any info proving otherwise and neither does anyone else, which is why the disagreements over which is best.
Stangninjak
324
#10
  • May 2, 2006
  • #10
My exhaust mods are in my sig. I can tell you though that I had a 2' inch before, and it was choking the living crap out of my old 351..but then again, its a 351. The older 351 I had was also very stockish.
My new system sounds dam good. Its not super loud though, and inside its mild. I do not even have sound dampers. Its just a nicelow rumble. I have a lot of people tell me it sounds good. Is it worth redoing ? Well your pockets need to decide that one.
Max Power
1,774
St Paul
May 2, 2006
#11
  • May 2, 2006
  • #11
Through stock heads and tri-Ys, 2" isn't holding you back too much.
It wouldn't be a noticable increase to go bigger, and if you actually did get any gains, it would be towards the rpm level where your heads would crap out.
67topless
203
Raleigh, NC
May 2, 2006
#12
  • May 2, 2006
  • #12
How about this... what were the stock exhaust applications out of the factory?
I had a 2 barrel 289 with the single exhaust which I think was 1 1/2 inches right? In addition, I think the stock setup was 190 flywheel HP correct?
What was the stock exhaust configuration for a dual exhaust 289 HiPo? Can you use these types of examples as a baseline?
Just curious...
Sicarius428
2,085
May 2, 2006
#13
  • May 2, 2006
  • #13
2 inches is fine for your application. If you go bigger you might loose out on torque. No need to redo your exhaust unless it needs replacing.
Kevin
57fairlane
560
Oakwood, GA
May 2, 2006
#14
  • May 2, 2006
  • #14
David Vizard did one back in the late 80s. He found that each horsepower needs 2.2 cfm.
stangkid88
112
Seattle area
May 2, 2006
#15
  • May 2, 2006
  • #15
this is the same thing I was hoping to do for my exhaust system. If you don't mind me asking, where did you order the system from and how much did the shop charge to weld it up? Thanks for any help.
G
GNN60GT500
1,218
26
48
5 car lengths in front of you!
May 2, 2006
#16
  • May 2, 2006
  • #16
The other thing to consider is that depending on what mufflers you are using, this will also change the chart around as well-
As a straight through 2.5" muffler will support more power then a chambered 2.5" muffler-
At Magnaflow, this is what we usually go by- this is for a N/A motor, no converters - with an X pipe
These are crank hp numbers- and would be an exhaust for a street driven car with light track duty, for a race car, I would go to a bigger exhuast sooner-
With forced induction, depending on power adder- you could also go to a bigger exhaust as well a little sooner-
0-225hp 2.25"
225hp- 550hp 2.5"
550hp- 900hp 3"
For a chambered exhaust- there are numbers I see some of our competitors use-
0-200hp 2.25"
200hp-475hp 2.5"
475hp-800hp 3"
SoCalCruising
2,437
SoCal
May 2, 2006
#17
  • May 2, 2006
  • #17
Ha! Somebody else read the David Vizard article! One thing he points out is that the entire exhaust system will flow only as well as the most restrictive component. So, if you pop for headers and 2.5" pipes, but your muffler flows a cfm number equivalent to a 2" pipe, guess what? It acts like a 2" exhaust system. Unfortunately, few companies publish flow numbers in cfm. Of course, if all you want is the "right sound", ignore this.
19stang66
689
#18
  • May 2, 2006
  • #18
I take her in tomorrow morning at 830! I bought kit from Summit Racing and the headers from CJ Pony Parts. I'll let you know tomorrow how much it cost for the shop to do welding, hopefully not a lot.
K
Kman
620
Connecticut
May 3, 2006
#19
  • May 3, 2006
  • #19
Stock K codes (HiPo's) used a 2" system from the manifolds back. That's what I still use on my K along with a pair of Flomaster 40's. Runs just fine and sounds very nice.
Cobain03
996
Lexington, Ky
May 3, 2006
#20
  • May 3, 2006
  • #20
is your k code stock?
1 of 2 Next Last
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
