  • SN95 4.6L Mustang Tech
Explanation???
  • Thread starter Thread starter blacknblue2002
  • Start date Start date Dec 20, 2007
blacknblue2002
159
Va Beach, Va
Dec 20, 2007
  • Dec 20, 2007
I was wondering if anybody could give me a brief description of what the IAC actually does? I know that it controls the idle and that there is a tiny little solenoid that is inside, but I have no idea how it communicates to the engine, what data it's getting, and the overall purpose of the solenoid.
I've done a little research and couldn't really find a description that fit my question. I'm trying to figure out why my car idles very poorly when I first crank it, but then generally cures itself after a couple of minutes and acts somewhat normal (except for exaggerated hanging rpms and sometimes erratic bounces of rpms).
Does anybody know if the IAC is used differently after the car warms up, or if the ECM changes over to a different portion of the program after the car has been on for a couple of minutes. This just doesn't make sence to me.
trinity_gt
3,125
81
99
Canada
Dec 20, 2007
  • Dec 20, 2007
Think of the IAC as nothing more than an air passage around the throttle plate. The PCM uses the solenoid to control the size of that bypass; when it's open far, lots of air gets into the engine and the idle speed rises. When it's open just a little, not much air bypasses the throttle plate and the engine slows. The PCM is continually modulating the solenoid at idle to allow just enough air around the throttle plate as to achieve the desired idle speed.
The desired idle speed -- the speed the PCM wants the engine to idle at -- certainly changes in response to coolant temperature, run time and so on.
You might consider getting a scan tool on the car and looking at the reported coolant and inlet air temps, MAF, fuel pressure, fuel trims and so on. If the car definitely cleans up after a couple of minutes, you may have an open-loop (that is, the PCM isn't yet relying on feedback from the O2 sensors to set the fuel delivery) fuel delivery issue, perhaps running too rich. When the sensors heat enough to produce useful output, the PCM adjusts the mixture to the correct value, cleaning up how it runs...
Superhereaux
chicks make me feel inadequate
538
South Texas
Dec 20, 2007
  • Dec 20, 2007
the above post is correct
when the a/c compressor kicks on or you turn the steering wheel (or apply the brakes since it's hydroboost) the rpms drop and the IAC compensates to keep idle speed constant
blacknblue2002
159
Va Beach, Va
Dec 21, 2007
  • Dec 21, 2007
thanks,
that was a very helpful answer. I'm still working on this, and maybe I can use my x-cal to datalog and figure out what's going on...it's still hard to believe that there are about 10-15 different reasons why my car could be acting the way it is and it's killing me trying to narrow it down. I've got shop time next week at a local tuner, and he said he'd look at it with me while I'm getting the other work done to my car. If I can't get it ironed out by then, I'm hoping he'll be of some help
[BlackDiamond]
119
  • Dec 22, 2007
on this same note, with the AC/Defrost turned on, is it normal for the idle to stay at the normal 800 rpm range, then rev up to 1200 rpm for 2 seconds, then drop to 800 rpm for 10 seconds.. and then back up again?
I just want to make sure, because mine does that, and I'm not sure if its just means to be at like 950-1000 rpm constantly, or if its really supposed to "zig-zag" like that?
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
Did an auto reset procedure earlier, few questions
  • from6to8
  • Jun 19, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 19, 2024
from6to8
KNOCK WITH CLUTCH OUT
  • Scwhitten
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
N
50 miles on 1/2 tank of gas
  • NooStang
  • May 13, 2024
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2025
NooStang
N
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
