explorer/cobra
slow5poh
Senior Citizen
Jul 6, 2005
273
Citrus Heights, CA
if explorer motors are used for gt40p heads, cobra style intake, why are those exploders so damn slow? my buds 99 5.0 sucks. but i guess it's heavier. also if a 93 cobra has gt40 heads, bigger injectors, better intake, etc, why is it only worth 20 more hp than a 93 gt?
:shrug:
I don't think the 5.0 (shiortblock) in the Exploder is the same as the one in the GT. All it would take is a different cam to really throw off the results of the same parts. Also, the '93 Cobra and GT had different cams, which may be why the GT40 heads and Cobra intake aren't worth that much on a stock GT without a cam change. It's also worth mentioning that the '93 Cobra was under rated at 235hp.
96 thru 2001 explorers/mountaineers are 5.0's.
I'm trying to figure out the difference in mustang and explorer performance myself. Cams are "close" in lift, duration, and lobe seperation. Heads are better than regular HO heads.....actually smaller valves but more velocity (read ROUSH trans am car article on 310 ci engine putting out over 700 hp, in 1997!) intake is simular to GT-40 on 93 cobra, explorer has bigger throttlebody, but is still a pig probably weighing in at no less than 2000 lbs more than a stock 87-93 GT. A buddy of mine said well the explorer has a more restrictive exhaust than a stock 87-93 5.0........which is prolly true. But why doesnt the explorer rev as high as the 87-93 HO motor???? cam?? valve springs??? exhaust restriction........with not as much restriction on the intake side??? that is what I think........once a explorer engine is put into a stang the exhaust (being less restrictive) actually matches the good intake air flow better, better allowing it to breath. Making it more efficent therefore making it perform better! just my hunch!
we're liable to see in a few weeks! Because I may leave the stock explorer cam in when I do my swap. I'll be doing a dyno baseline before and after as well!
Jack
'99 is a 302. I have one and it has flattop pistons with 4 small valve reliefs. They are fully skirted around the wrist pin. Also has the plastic retainer for the lifters and a non-roller silent type timing chain.
I might measure the cam when I have time. The exhaust lobe is visually way bigger than the intake. Probably due to the crappy exhaust manifolds they used.
'02 is the aluminum block 4.6 liter. The 4.6 is sweet except for the auto transmission they use. Basically a hopped up glorified c3 pinto tranny.
so maybe a 93 cobra is like 250hp? btw, i used to have a teal 96 z28 camaro. At the ford dealer across the street from where i work like 2 years ago they had a 93 teal cobra. back then i knew nothing of mustangs and they had it advertised for 10 grand. it had been the owners car. It had black leather, black interior, low miles. It was probably a good pirce, but i didnt know that. I sure wish now i woulda traded my z in and financed the rest. Instead i bought a clean gt but paid 5600 for it, and im in on it like 2500 already, so i shoulda just bought the cobra.
:bang: :bang: :bang:
Umm...if I give you mine, then I guess I'll have to take the one off of my wife's 97 Explorer XLT 5.0
Sounds fair to me...... :banana:
-yep, between her t-top GT, my cobra, and the 2 Explorers, we've got 4 5.0's
or is that a 20.0 ??????? :p
