well somebody local is selling one for 100 Bucks !
so I decided what the hell.. the Heads are in the shop ... my typhoon intake is ported and would be way over kill... and I dont feel like going through there and swapping a cam.
so I got the intake and there is a film of black grease oil stuff... what should I do to remove this? I went through it checked it all out it looks okay...
what gasket part numbers should I get and I wouldnt mind touching up the lower a bit to a larger gasket...
I also need most bolts for the intake and gaskets to install the 65mm TB. can I buy all this at a local speedshop?
and last but not Least ... with the explorer intake (gasket matched) maybe a slight bit of porting and a 65mm TB net about 20rwhp?
I want more power.. above 5k as well too..
Thanks !
Thanks !
