extreme energy 282 cam
  • Thread starter Thread starter rednotch88
  • Start date Start date Jul 30, 2009
R
rednotch88
151
CHICAGO
Jul 30, 2009
  • Jul 30, 2009
I know this may be a noob question...What is the lift different from 1.6 to 1.7 rockers on a EX 282HR cam? cam alone is .565int .574ext.
KJ
89stang1
Stroked and Juiced
730
234
74
nj
Jul 30, 2009
  • Jul 30, 2009
Kinda of a guess from what i remember i think the same cam translates into a 100 more on the 1.7 rocker
nick6690
147
McDonough, GA
Jul 30, 2009
  • Jul 30, 2009
divide the lift by 1.6 and then multiply by 1.7
so around .600/.609
you also get more duration but im not sure how to figure that out.
lincoln+ford
195
  • Jul 30, 2009
i thought going from 1.6 to 1.7 usually ment add .30 to the lift
R
rednotch88
151
CHICAGO
Jul 31, 2009
  • Jul 31, 2009
So what you guys think??what is the verdict?
R
rednotch88
151
CHICAGO
Jul 31, 2009
  • Jul 31, 2009
so around .600/.609
so what is the equation here...?
nick6690
147
McDonough, GA
Jul 31, 2009
  • Jul 31, 2009
.565/1.6= .353 .353x1.7=.600
.574/1.6= .358 .358x1.7=.609
those numbers aren't rounded btw.
R
rednotch88
151
CHICAGO
Aug 1, 2009
  • Aug 1, 2009
cool.well what piston will have reliefs that big for 609 lift.???
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Aug 1, 2009
  • Aug 1, 2009
Roller rockers do nothing but magnify the lift from the cam, based on the ratio of the RR. A lot of times, cam lift is stated assuming a 1.6 ratio, but you have to read the fine print. Roller rockers do not increase the duration, but again, it gets kind of confusing. A cam's duration is typically measured from some amount of measurable lift (usually .050 IIRC), rather than the actual opening event (where the dwell period ends but before any lift has begun). So if the RR magnifies the lift, the cam gets to .050 lift sooner, which makes the duration SEEM longer. Actual open to actual close of the valve does not change.
Also, maximum lift doesn't directly affect clearance needed. Its more a function of valve overlap between the exhaust and the intake strokes, and where the valves are during this period.
R
rednotch88
151
CHICAGO
Aug 2, 2009
#10
  • Aug 2, 2009
  • #10
but won't i have some clearance issues?piston to valve clearance?I need to learn a little more on the combustion chamber action ect..
57fairlane
560
Oakwood, GA
Aug 2, 2009
#11
  • Aug 2, 2009
  • #11
thats why you clay it or use weak springs to check your actual clearance or lack of.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Aug 3, 2009
#12
  • Aug 3, 2009
  • #12
yea best way to find out is to check the piston to valve clearance, but if your running that cam why do you want to run 1.7 rockers? unless you really need the extra lift is kinda pointless, thats a good sized hyd. roller cam. whats the rest of the combo?
R
rednotch88
151
CHICAGO
Aug 3, 2009
#13
  • Aug 3, 2009
  • #13
I don't know what the combo is going to be yet.I'm still working on the rear end/rear suspension.. I have a set of 1.7's already i'd like to use em.I would like it to be an all motor car-High compression ect....as for heads...I dono wtf i'm going to do.I juut built this whole car and not im running out of money when I get to the cool stuff.
89-347-LX
38
Oklahoma
Aug 5, 2009
#14
  • Aug 5, 2009
  • #14
dont cut corners. if you need to wait a little bit then do, call one of your buddys (when your motor is ready to be put together) and have him degree the cam for you and check PTV clearance. LIFT on a cam is one of the last things that matters when checking PTV clearance. do it right the first time
R
rednotch88
151
CHICAGO
Aug 5, 2009
#15
  • Aug 5, 2009
  • #15
cut corners
stangboy
3,932
469
194
New Orleans, LA
Aug 12, 2009
#16
  • Aug 12, 2009
  • #16
I agree with 89-347-LX 100%. If you run out of money and end up with a car with hellified suspension with a stock motor, so be it until you build your funds back up to do the motor right. When I built my 94GT it took me 3 years of stock-piling parts before I actually put it all on the car. My car went from stock non-contender to a decent contender over the course of 2 weekends. It would have been 1 weekend but I ran into PTV clearance issues on Sunday night of the 1st weekend and had to extend the valve reliefs on my pistons with a dremel tool the next weekend.
The look on all my friends' faces when I was whoopin' a$$ and takin' names was priceless.
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
P
Cam spec
  • peter.farina
  • Oct 27, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2024
TOOLOW91
SN95 New Heads
  • Blakeknight
  • May 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
