I have a ford motorsports F-303 camshaft and I was wondering if I must degree it in. I have never done this and I am told that alphabet cams you line up dot to dot with the timing marks, is this correct? Also, if I do degree it, am I just measuring the camspecs or do you measure just if you plan on advancing or retarding the cam (I want to run straight up)? I see no adjustablity in the cam or timing chain itself, so if I degree it and a measurement is off, how do I know the nubers are off and what do I do to fix it. In general I don't understand what you are "degreeing" actually, exept to make sure the motor is at tdc and the timing chain marks are aligned, which is obvious (heads are off) Why would I need a degree wheel to measure the cam, it seems to only go together one way, there seems to be no adjustablility in the set-up even if my valve events are found to be "off".
Also I have an aftermarket timing chain that seems to be indestructible compared to any other chain I have seen, but it seems to be loose fitting, lots of play/slop, but doesn't seem to be able to jump a tooth. Is this play ok? Is it streched? How can I test it? What can you do to the motor to make it stretch a hardcore timing chain? I'm not sure the brand, but I know it is pretty new(less than 15,000 miles) Any one that canm help me I would be very appreciative, thanks
