Opinion, facts, experiences all welcomed...
which cam would you rather have in a Daily Driven Fox with
EDELBROCK PERFORMER RPM WITH 1.90" INTAKE VALVES
TRICK FLOW SPECIALTIES STREET HEAT INTAKE
STOCK BOTTOM END, want to run 1.6 rockers to avoid PTV CLEARANCE
Cam specs are as follows
F-cam Intake Duration at 050 inch Lift: 226
Comp Intake Duration at 050 inch Lift: 218
F-cam Exhaust Duration at 050 inch Lift: 226
Comp Exhaust Duration at 050 inch Lift: 224
F-cam Duration at 050 inch Lift: 226 int./226 exh.
Comp Duration at 050 inch Lift: 218 int./224 exh.
F-cam Advertised Intake Duration: 288
Comp Advertised Intake Duration: 270
F-cam Advertised Exhaust Duration: 288
Comp Advertised Exhaust Duration: 276
F-cam Advertised Duration: 288 int./288 exh.
Comp Advertised Duration: 270 int./276 exh.
F-cam Intake Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
F-cam Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Comp Intake Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Comp Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
F-cam Valve Lift with Factory Rocker Arm Ratio: 0.512 int./0.512 exh. lift
Comp Valve Lift with Factory Rocker Arm Ratio: 0.512 int./0.512 exh. lift
F-cam Lobe Separation (degrees): 114
Comp Lobe Separation (degrees): 114
TIME BUT THE POWER DOSENT FEEL LIKE IT KICKS IN TILL 3000 RPM BUT PULLS TO 6500 VERRRY GOOD.
