f303 cam help
  • Thread starter Thread starter BigHoss91GT
  • Start date Start date Jan 17, 2006
BigHoss91GT
11
  • Jan 17, 2006
hey everyone i have a 91 gt and its an AOD. i have cold air intake, 65mm t/b, edelbrock performer intake, shorty headers, pulleys, o/r h-pipe, flowmasters, 4:10 gears, 24lb injectors, nirtous, and a ford f303 cam. do you think im alright with the cam and everything or do youthink the cam will not work right. also im gonna try and get msd 6al box and msd distributor and 2400 stall converter. Also what do you think my ET's will be w/ street tires. 125 shot nitrous
Thanks
Brad
Jozey
127
Tucson,AZ
Jan 17, 2006
  • Jan 17, 2006
if you are running stock heads it will not work.you will have to fly cut your pistons to fit the lift of that cam.if you have stock heads a E-303 or B303 will work good for you.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jan 17, 2006
  • Jan 17, 2006
It might actually work , when you get to that point , its not the lift but the longer duration that is going to be the cause of interference .....people put Ecams in with 1.7s rockers which makes .529 lift but they work because of the shorter duration ....I would say you only have a 50/50 chance of it working out for ya as long as you use 1.6 or stock rockers .....
fastimes69
188
San Benito, Texas
Jan 17, 2006
  • Jan 17, 2006
Yes it will work, my cousin runs a similar set up to yours, all stock (even heads) with no probs. I ran the f cam with 1.7's on my stock ported heads and no problems either!!
just4bob50
504
Pa.
Jan 17, 2006
  • Jan 17, 2006
I know of 2 different people running the f-cam with stock heads, but both of them have 1.6 rockers and no problems. My brother for a short time ran a lunati 512 / 512 lift cam with his stock heads and had no clearence problems.
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
9
Engine 94 GT breaking up
  • 996stang
  • Sep 21, 2024
Fox 5.0 Mustang Tech Sep 26, 2024
AeroCoupe
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
