  • 1994 - 1995 Specific Tech
Fail Emissions
  • Thread starter Thread starter gt96stanggt
  • Start date Start date Aug 30, 2005
G
gt96stanggt
106
Tempe, AZ
Aug 30, 2005
  • Aug 30, 2005
Yeah failed becuz they found a line blocked off with a screw WTF anyways it a line conected to the "canister purge regulator valve". it has 3 connections coming off of it. 1 goes in to wiring. 1 down to the gas tank?. and the other is blocked off with the screw. any one know what im talking about or where it goes?
http://i5.photobucket.com/albums/y167/Antizer00/IM002028.jpg
http://i5.photobucket.com/albums/y167/Antizer00/IM002029.jpg
http://i5.photobucket.com/albums/y167/Antizer00/IM002030.jpg
if they dont help any let me know and ill get better ones.
94opalgt
358
AKRON,OHIO
Aug 30, 2005
  • Aug 30, 2005
yeah that hose is supposed to be connected to the upper intake.underneath it from the back.dont know why someone would plug it,its for vaccum.plug it back in.
G
gt96stanggt
106
Tempe, AZ
Aug 30, 2005
  • Aug 30, 2005
Do u know exactly where it goes beucz i cant find where it goes?
G
gt96stanggt
106
Tempe, AZ
Aug 30, 2005
  • Aug 30, 2005
come on now you can't tell me that only one person here knows what it is and where it goes...
i really need to get this done i dont know how or why my bank knows about it but they want me to get it done this week. well on 2nd thought maybe its becuz i have a loan through them
9
94GTNJ
94
  • Aug 30, 2005
As stated above it connects to the upper intake, on the bottom side. If your looking at the engine from the front, look at the right hand side of the intake and then just try your best to look underneath of it. There should be vacuum nozzles that you just plug the canister rubber hose to.
Or just look at the right fuel rail, the nozzle should be right above it.
bimmertech
1,123
merriam, ks
Aug 30, 2005
  • Aug 30, 2005
exactly where he said it is, or anywhere it'll fit on the upper as the vac source is all the same on the upper.
V8302stangs
211
San Jose, CA
Aug 30, 2005
  • Aug 30, 2005
I can take a picture of mine tomorrow.
G
gt96stanggt
106
Tempe, AZ
Aug 30, 2005
  • Aug 30, 2005
That would be most helpful.... ive looked for it.. i dont know why but i have a feeling that i am going to feel stupid once i know exactly where it goes.
G
gt96stanggt
106
Tempe, AZ
Sep 1, 2005
  • Sep 1, 2005
ehh its the only place i could find although it doesnt seem like it goes there just because its a bent and stuff but i dont know you tell me? not the best of pics.. <--side is where the front of the engine is.. and those mozzle were about in the middle both blocked with condoms (bro in law called it that) like the one right behing the hose
http://i5.photobucket.com/albums/y167/Antizer00/IM002047.jpg
http://i5.photobucket.com/albums/y167/Antizer00/IM002049.jpg
94opalgt
358
AKRON,OHIO
Sep 2, 2005
#10
  • Sep 2, 2005
  • #10
well the vacuum hose thats in the pic shouldnt be like that.if its bent like that youre not getting anything through it cuz its kinked so bad.the hose needs to be longer so it does not bend like that,but that is exactly where it is supposed to go
Pokageek
2,767
MA, USA
Sep 2, 2005
#11
  • Sep 2, 2005
  • #11
Good luck getting a hose in there. You nearly have to take the intake off or have houdini hands. I don't know why they designed it like that.
G
gt96stanggt
106
Tempe, AZ
Sep 2, 2005
#12
  • Sep 2, 2005
  • #12
ehh it passed thats all that matters right now.. i guess ill just get a longer hose tomorrow or something.. now its time to put the o/r h pipe on
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 3, 2005
#13
  • Sep 3, 2005
  • #13
Those vacuum lines need to be redone. They are so pinched that I doubt they are even receiving vacuum.
Once you redo those vacuum lines, get one vacuum T coupler, and one straight coupler. Extend the vacuum line that you pictured in your first post to reach those lines underneath the intake, and then cut one of the other vacuum lines, reconnect them back together using the vacuum T coupler, and join the other line to that coupler...Then you are done.
Scott
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
CFI to carb conversion question
  • StockerStang
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2025
AeroCoupe
A
Vacuum line help
  • Artyom
  • Aug 27, 2024
  • 2 3
4K
1994 - 1995 Specific Tech Sep 26, 2024
Artyom
A
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
