Failed Emissions
  • Thread starter Thread starter Griswald
  • Start date Start date Nov 16, 2010
Griswald
33
CA
Nov 16, 2010
  • Nov 16, 2010
Well, 3 days ago I bought an 89 5.0 notch, bone stock, with about 92K mi, and I think everything except the plugs and an AC line is original.
Apparently, I have a high amount of HC gas, which the guy said was un-burnt fuel. He suggested 02 sensors, spark plugs, or something in the EGR.
Guy I bought it from told me he just changed the plugs, but gapped them at .054. In my Chilton manual it says .044. Is this something I should correct right away?
Listening from the pipes, it sounds good. Inside the car it sounds like it idles rough, and sometimes shakes, I can feel it through the steering wheel and the shifter. Otherwise it seems to run pretty good under acceleration going through the gears.
Any suggestions would be great!
Thanks,
Chris
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Nov 16, 2010
  • Nov 16, 2010
Stock gap is 0.054" for your year. The chiltons incorrectly quotes the 79-86 gap for the 87-93 as well.
Run your codes. Even if the cel is not on, codes can be stored. Only about 11 of the 100 codes actually trip the light on obd1 systems.
HISSIN50
34
129
Nov 16, 2010
  • Nov 16, 2010
After you pull KOER codes, run a cylinder balance test.
Griswald
33
CA
Nov 16, 2010
  • Nov 16, 2010
Thanks guys! Check engine light came on yesterday, but has not came back since I turned off the car (yesterday). I've been so busy with all the DMV and registration stuff, I haven't had a chance to look at anything. I will check the mentioned suggestions.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 16, 2010
  • Nov 16, 2010
How to pass emissions testing:
High NO - high combustion temps - retard timing, check EGR for operation.
High CO – Rich condition - fuel pressure too high, check O2 sensors, replace air filter, Clean MAF element.
High HC – Lean misfire, vacuum leak, common misfire due to worn or weak ignition system components. On rare occasions, an overly rich mixture may be the cause. Do the ethanol/E85 fill up as suggested.
High CO & HC - Cat converters, smog pump, and smog pump controls.
1.) Make sure all the emissions gear the car was made with is present and connected up properly. That includes a working smog pump and cats. The smog tech will do a visual check to make sure that all the original equipment is present and connected up.
2.) Make sure that you have fresh tune up with spark plugs, plug wires, cap, rotor, fuel & air filters. An oil & filter change is a good idea while you are at it.
3.) Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
4.) Post the codes and get help to fix them. Don’t try to pass with codes not fixed. Clearing the computer just temporarily removes them from memory, it doesn’t fix the problem that caused the code to be set.
5.) Be sure to do the testing on a hot engine. Drive for 15-20 minutes prior to taking the test to get operating temps up into the normal range. Do not shut off the engine while waiting for your turn on the test machine. An engine up to full operating temperature puts out fewer emissions.
Griswald
33
CA
Nov 16, 2010
  • Nov 16, 2010
Holy crap man! Thank you!!!!
Griswald
33
CA
Nov 18, 2010
  • Nov 18, 2010
I did the KOEO test, and got code 91. I've seen charts listing oxygen sensors (so I installed new Bosch ones), and another listing for SS1 Shift Solenoid Circuit Failure? Through some searching, I can only find the SS1 code for automatic transmissions. I have a 5-speed manual. Am I missing something?
Am I on the right path with the 02 sensors? I haven't fired the car up yet because I'm still in the middle of plugs, wires, and distributor.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 19, 2010
  • Nov 19, 2010
On a 5.0 Mustang, the code 91 is O2 sensors.
Code 41 or 91 Three digit code 172 or 176 - O2 sensor indicates system lean. Look for a vacuum leak or failing O2 sensor.
Revised 24-Sep-2009 to correct computer pin description for 94-95 5.0 Mustangs
Code 41 is a RH side sensor,
Code 91 is the LH side sensor.
Code 172 is the RH side sensor
Code 176 is the LH side sensor
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel. Many times the end result is an engine that runs pig rich and stinks of unburned fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than 400 Millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than 600 millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage." End Quote
Testing the O2 sensors 87-93 5.0 Mustangs. Note: an Analog voltmeter or Digitial voltmeter with a bar graph is needed for this test. A regular Digital voltmeter will give inaccurate results.
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Testing the O2 sensors 94-95 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 43 (LH O2 with a red/black wire) and 44 (RH O2 with a gray/lt blue wire). Use the metal next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them.
Testing the O2 sensor wiring harness
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
Make sure you have the proper 3 wire O2 sensors. Only the 4 cylinder cars used a 4 wire sensor, which is not compatible with the V8 wiring harness.
Replace the O2 sensors in pairs if replacement is indicated. If one is weak or bad, the other one probably isn't far behind.
If you get only code 41or 91 and have changed the sensor, look for vacuum leaks. This is especially true if you are having idle problems. The small plastic tubing is very brittle after many years of the heating it receives. Replace the tubing and check the PVC and the hoses connected to it.
A secondary problem with only a code 41 or 91 is for cars with an intact smog pump and cats. If the tube on the back of the heads clogs up, all the air from the smog pump gets dumped into one side. This excess air upsets the O2 sensor calibration and can set a false code 41 or 91. The cure is to remove the crossover tube and thoroughly clean the insides so that there is no carbon blocking the free flow of air to both heads.
Griswald
33
CA
Nov 19, 2010
  • Nov 19, 2010
Awesome! Thanks again man!
Griswald
33
CA
Jan 8, 2011
#10
  • Jan 8, 2011
  • #10
I DID IT!!! Finally got 11, 10, 11! I want to thank jrichker for the lengthly info. When I got this car 2 months ago, I knew NOTHING about Mustangs. I was confused at first, but after reading jrichker's advise daily, it started to make sense. Also taking a few parts off the car, and messing with them in the driveway, helped get a visual of how things were supposed to function.
I got rid of the codes 91 & 41 by changing the blue vacuum check valve (was able to blow and draw air through it), cracked TAD & TAB solenoids, and EVR.
I got rid of the code 34 by grinding a TINY amount off the EVP sensor rod (less than 1/32"). I found that adding vacuum to the EGR, would push the rod back, which in turn would raise the voltage. I was at .77 volts, and after grinding I was at .44 volts.
bp50
21
so.cal
Jan 8, 2011
#11
  • Jan 8, 2011
  • #11
About the check valve, did you purchase a generic piece or is it specific to the Mustang,
I got to check mine. I still have codes 41,91 after replacing all rubber vacuum lines.
Griswald
33
CA
Jan 8, 2011
#12
  • Jan 8, 2011
  • #12
I took it to Kragen, told them what I had, and the guy said he wasn't sure what he ordered would be the right thing. It looks the exact same, just no Ford logo on it, and air only passed through one way. My TAD/TAB solenoids kinda seemed ok, but I changed them too because they were starting to crack.
bp50
21
so.cal
Jan 8, 2011
#13
  • Jan 8, 2011
  • #13
Great info Thanks!
Griswald
33
CA
Jan 11, 2011
#14
  • Jan 11, 2011
  • #14
PASSED EMISSIONS!!!
J
Switched to e85 on the 3v and now it won't run right.
  • jcowdough
  • Aug 24, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 24, 2025
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
J
  • JRC99
  • Apr 19, 2025
JRC99
J
