Falcon/Mustang engine swap questions...
reenmachine
Jun 27, 2004
1,258
Montrose, CA
I've got a strong 200 6-cyl from a '67 Mustang sitting in the garage. A friend has a '64 Falcon with a 6-cyl that runs like crap. I'm assuming the Falcon has a 170. I want to dump this 200 into her Falcon. I figure it'll be a direct bolt-in -- is there anything I need to know? She's probably got a generator & this engine has an alternator. It'll probably be easiest just to put the generator on this engine if the bracketry works out. Can I switch her to alternator electrics with minimal hassle? Is the harness very different?
Is there a good Falcon forum where I could find some answers?
Thanks in advance.
Thanks in advance.
Falcon and Mustang are pretty much the same car, if you want to go with the alternator just wire it like a 65, I can send you the diagrams if you need them. Hit me @ [email protected] and I'll send them to you.
Thanks. I've got all of the wiring diagrams and all of the shop manuals, so I should be good to go. It's just that the Falcon is 400 miles away so I just wanted to make sure I have all my ducks in a row before I schlep everything out there.
If I remember from my Mustang 200 swap into a 62 S-22 Comet, the bell housings are a different diameter. The older one will bolt up if you relocate the guide pins. I think that 200 has two bolt patterns for the trannies. I kept all the old stuff and installed a HD Econoline clutch after I was finished because the 200 would just spin it without going anywhere. Awesome swap though!
