- Jun 11, 2004
- 5
- 0
- 0
well i took most of my cooling system off (radiator, fan, shroud) and cleaned it up today. when i seperated the fan clutch from the fan it was caked with dirt and grime. the reason why i took everything apart was because i got up to 250*! I have a new t-stat with maybe 100 miles on it so it left me to believe that it was either my fan or the radiator. my waterpump still flows coolant so it cant be that.
My question is...are you supposed to be able to spin your fan after the engine has reached normal operating temp, let's say 190*? i heard you aren't supposed to be able to, bt i could spin mine all day i if i wanted. i noticed one or two teeth on the fan clutch were missing and some had rounded edges (dunno if that's how they're supposed to look). do i need a new fan clutch or are you supposed to be able to spin the fan?
