Fan Controller Question
  • Thread starter Thread starter theconductor
  • Start date Start date Jul 20, 2024
theconductor
337
96
74
Roseville, CA
Jul 20, 2024
  • Jul 20, 2024
I have been using Contour fans with a Derale controller for quite a few years without issue. In the meantime, I swapped out my factory ECU with a Megasquirt PNP. Realizing recently that the MS can be used as a fan controller, would it be ideal to go this route instead of the separate controller?
I will be pulling the ECU out for another hookup, so I'll have a good opportunity to add the controller function to it.
Thanks!
nickyb
I gotta say i never painted my nuts, Never Ever
3,044
1,671
163
nevada
Jul 20, 2024
  • Jul 20, 2024
I haven't installed my mspnp 2 yet so let us know how you get this done.
Reactions: theconductor
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jul 22, 2024
  • Jul 22, 2024
I've done this little controller with Megasquirt
PWM Fan Control
I know this has been discussed elsewhere and isn’t anything spectacularly new, but recently I did a little playing around with this and made a few videos. There's a lot of OEM fan controllers out there that can be used with various ECU's. I got my hands on a few but settled on one that I was...
stangnet.com
theconductor
337
96
74
Roseville, CA
Jul 23, 2024
  • Jul 23, 2024
PWM Fan Control
stangnet.com
Thank you for the response. I'm not very sharp with this stuff, so bear with me. . .
If I use the MS turn the fan on and off, I would still need to use my current pwm fan controller right? Would the MS tie in to the input on the controller that is now connected to the temp sensor?
Also, does MSPNP2 now have a PWM output?
Thanks
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jul 24, 2024
  • Jul 24, 2024
No, you have to make a decision. Use existing PWM controller independently, or grab one of those OE type controllers and use parameters within MS to control it. The new firmware for MS (1.6.0) offers a specific PWM fan control menu.
I admit, this can be a little bit tricky for someone not familiar with how the system works and PWM signals and control
No. The MS will take it's temp readings from the engine coolant sensor, along with other readings from various sensors. It uses that info, along with what is programmed into the PWM fan control menu to output to the OEM stle PWM controller via a single wire.
Essentially the MS is the brain, compiling info from all the sensors used to run the engine, and outputs to the controller via a single wire. Paremeters you can control are things like the fan run % based on coolant temp, turning the fan OFF over a certain MPH (based on VSS readings) and forcing the fan on if you turn the AC on. You can also tweak these settings in MS.
Thanks
I have an MS3pnp, but looking at the MS2 it does look like there are available outputs that can be configured for PWM.
Reactions: BrightVa
theconductor
337
96
74
Roseville, CA
Jul 25, 2024
  • Jul 25, 2024
I have an MS3pnp, but looking at the MS2 it does look like there are available outputs that can be configured for PWM.'
Thank you for the help here. I'm not sure I'm ready to mess with all of that yet, but I'd like to have the pin wired for the future. Do you happen to know which one I would be using?
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,953
5,831
213
Jul 27, 2024
  • Jul 27, 2024
I ise my mspnp2 to control my hogh and low speed fans. I use ground trigger outputs ( forgot the pins ). They control two seperate relays. Been like this almost 9 years.
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 1, 2025
jacekk
J
Question on Chime Module and Airbag controller?
  • stevedjarrell
  • Jun 12, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2024
stevedjarrell
  • dan50
  • Jul 18, 2026
dan50
Mark VIII Fan/DCC Controller Combo Relay Size?
  • ZephyrEFI
  • Sep 4, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 21, 2024
FastDriver
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
