  • SN95 4.6L Mustang Tech
Fan problems
  • Thread starter Thread starter slick86gt
  • Start date Start date Jul 5, 2010
slick86gt
  • Jul 5, 2010
OK, I have a 96gt all stock except for exhaust. It was getting hot (past the 'l' in 'normal') so I flushed the coolant and replaced the thermostat. While purging the air I noticed that the fan doesn't kick on until the needle is almost to the 'a' in 'normal'. What might cause that and what do I need to replace?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 5, 2010
  • Jul 5, 2010
Check fuses, check low speed fans
check all of your fuses. Esp the fuses in the smaller engine compartment fuse box.
Does the high speed fan turn on when the AC is turned on?
What happens if the coolant sensor is disconnected?
Test BOTH speeds of the fans. I really suspect that the LOW speed fan is not working. The most likley cause is either a blown low speed fan fuse, bad fan, bad CCRM, or the incorrect fan has been used (single speed fan). Split the fan connector. Apply -12 volts to the black wire. Apply +12 volts one a at a time to the other two wires. Confirm that both the low speed AND high speed fan works.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 6, 2010
  • Jul 6, 2010
The fan should come on when the car gets to operating temps. If it is not coming on within a few minutes of start it could be the low speed relay. If the relay is bad it is located in the CCRM and would need to replace the whole unit. It really isn't serviceable unless you know your way around a circuit board and solder. Test the fan as stated above to rule it out. Check the fuses in the fuse box under the hood to make sure they are OK.
M
2001 cobra coolant crossover delete
  • Mike3
  • Jul 5, 2026
  • SVT Tech Forum
SVT Tech Forum Jul 12, 2026
Mike3
M
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 1, 2025
jacekk
J
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
