  • 1994 - 1995 Specific Tech
Fan removal help plz!!!
  • Thread starter Thread starter FordBaby
  • Start date Start date Nov 30, 2006
F
FordBaby
14
  • Nov 30, 2006
the motor is a 95 5.0 ho out of a msutang gt i cant get the freakin fan off the water pump for the life of me all i see is the big nut in between the fan and pulley is tehre any special way to get it off like is the nut reverse thread or sumthin?? someone plz help thnx
95cobraguy
637
11
Concord, NC by way of LI, NY
Nov 30, 2006
  • Nov 30, 2006
1. 95 mustangs came with electric fan, not a mechanical fan like you're working on.
2. to get the fan off u need a fan clutch wrench set or an air chisel to get the nut to turn, it probably is a reverse thread.
F
FordBaby
14
  • Nov 30, 2006
yes mabie it is a 94 then casue it has the intake elbow thing
95cobraguy
637
11
Nov 30, 2006
  • Nov 30, 2006
maybe i should have been clearer. every mustang from 94 on came with an electric fan. r u sure of the year car your working on?
94Blue302GT
704
Chicago
Nov 30, 2006
  • Nov 30, 2006
Elbow thing... hmmmm, the turn in the intake for the TB?
And yes, you can go to autozone and get the cluch tool for free to borrow.
Although, that has to be a messed car.
F
FordBaby
14
  • Nov 30, 2006
well i thought taht only the 94-95 mustang had the elbow for the tb
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Nov 30, 2006
  • Nov 30, 2006
t birds also had the elbow, nmaybe thats what its from
HISSIN50
34
129
Nov 30, 2006
  • Nov 30, 2006
It doesn't sound like a fox III fan set up (more like that on a Jeep, etc). I think we might need a pic to be helpful while not making guesses. Otherwise it's like asking you to guess what color I'm thinking of right now.
Good luck.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Nov 30, 2006
  • Nov 30, 2006
They also had electric fans didn't they?
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Nov 30, 2006
#10
  • Nov 30, 2006
  • #10
Nope. Just bought a 93 Thunderbird engine for a stock replacement for my GT. It has the exact same engine, but has the clutch fan on the water pump. The fan will come off - I used a long adjustable wrench and held on to one of the pullies while I pulled on the wrench. Came loose with a bit of effort. I don't remember if it was reverse-thread or not. If you're having trouble removing the fan, PM me and I'll double-check the fan.
As a FYI for everyone else, the 93 Thunderbird is the same shortblock and H/C/I as the 94-95 Mustang. The lower intake appears to be the 93 intake - it has the extra sensor tapped and installed. The metal heater lines also has an extra temperature sensor in it, and the back end of them are bent, not straight like the Mustang's.
They also have different emission lines, though the pump is the same. Different headers and motor mounts as well.
4Jenna
4,326
AZ
Dec 1, 2006
#11
  • Dec 1, 2006
  • #11
LOL...this is good stuff
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
D
Really need some fuel pump help. I can't take this anymore!!!!!
  • DeanS
  • Aug 7, 2024
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2024
weendoggy
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
