fan
  • Thread starter Thread starter Beasty306GT
  • Start date Start date Feb 28, 2011
First Prev 2 of 2
Beasty306GT
671
Oxford,Mass
Mar 3, 2011
#21
  • Mar 3, 2011
  • #21
mob said:
This is the one I used for my taurus fan. Thanks to Mustang5L5 for giving me the link and helping me wire it up. You basically have to use this controller to activate an 85 amp relay. The probe threads into the water outlet, at the top where most have a plug. You can use this for a contour fan setup but you will need to wire up two relays, and you will basically have them both come on full blast at a certain temperature, seems like over kill to me.
Derale Cooling Products 16749 - Derale Performance Deluxe Adjustable Controllers with Pipe Threaded Probes - Overview - SummitRacing.com
This is what i found..im going to use a taurus fan ..my question is is the relay that comes with this big enough or do i need a bigger relay...im confused ...40/60 amp relay with air conditioning override circuit. Includes 30 amp fuse. Fan amperage is critical with this unit, most dual fans with large amperage draws will require the use of two controllers.
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Mar 3, 2011
#22
  • Mar 3, 2011
  • #22
When these fans are running I believe they only pull something like 25amps. The problem is they spike on start up to like 85 amps. You can try and use the relay that comes in they kit, worst thing that'll happen is it'll blow and you'll need to change it, but, it is not rated high enough for the fan. Best bet is finding a bosch 85amp relay, and having the controller turn the relay on. The relay is a little difficult to find, I had trouble finding one. I wish I saved the site I got mine from but I didnt. There usually like 30 bucks.
Cobra912
1,777
11
39
Wish I was anywhere but here
Mar 4, 2011
#23
  • Mar 4, 2011
  • #23
get the dual contour fan, you won't regret it
The proform fan won't even come close, mine was a hunk of junk
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Mar 5, 2011
#24
  • Mar 5, 2011
  • #24
Here's my efan in the stock shroud mod if anyone cares.
http://www.stangnet.com/mustang-forums/755550-e-fan-stock-shroud-how-check-out.html
Beasty306GT
671
Oxford,Mass
Mar 5, 2011
#25
  • Mar 5, 2011
  • #25
well i ordered a dcc fan controller...does anyone know how long it takes to get?? brian doesnt respond to e-mails.... im also goin with the mark viii 2 speed fan so it should do the trick
aar0s
1,015
55
69
Mar 5, 2011
#26
  • Mar 5, 2011
  • #26
for some reason 6 weeks is coming to mind on that. from what i understand they are worth the wait.
J
Jeffs88
86
Northeast Ohio
Mar 5, 2011
#27
  • Mar 5, 2011
  • #27
I just received mine a couple days ago and ordered it around the 9th of Feb. so it took about 3 weeks. Looks like an awesome product.....
Now its time to head to the Pull a Part for a fan.......
Jeff
Beasty306GT
671
Oxford,Mass
Apr 8, 2011
#28
  • Apr 8, 2011
  • #28
Well got my 2 speed fan controller orderd it Mar 4 and recieved it April 8 so anyone who orderded one this should give u a timeline when u will get yours he also sent an email with tracking number from paypal
First Prev 2 of 2
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
T
What's it Worth? 1979 Ford Mustang Cobra
  • toasterboy1
  • Nov 5, 2024
  • What is it Worth?!?!?
2K
What is it Worth?!?!? Sep 8, 2025
