DDSTANG94 New Member Dec 9, 2006 465 2 0 FRASER, MICHIGAN Nov 23, 2008 #1 Nov 23, 2008 #1 like the tittle says how to adjust hood bump stops. one of mine is loose and rattels over bumps, im trying to due it now so a quick answer would help
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Nov 23, 2008 #2 Nov 23, 2008 #2 You simply turn them. CCW raises the stop (for if the hood closes too far, or below the fenderline). CW lowers the stop, in case your hood barely closes or sits higher than the fenderline.
DDSTANG94 New Member Dec 9, 2006 465 2 0 FRASER, MICHIGAN Nov 23, 2008 #3 Nov 23, 2008 #3 HISSIN50 said: You simply turn them. CCW raises the stop (for if the hood closes too far, or below the fenderline). CW lowers the stop, in case your hood barely closes or sits higher than the fenderline. Click to expand... k thank you
