Faulty Window Regulator?
  • Thread starter Thread starter DusterRT
  • Start date Start date Jul 25, 2007
D
DusterRT
9
Seattle, WA
Jul 25, 2007
  • Jul 25, 2007
I just picked up a '67 coupe to play with and I've been attacking all the little things that come with a far from perfect driver..
One of my main concerns is the passenger side door glass; driving down the road, it will usually roll itself down 3/4" or so, and if you press down on the top of the glass, it rolls down with very little resistance. It cranks up and down just fine, doesn't skip teeth or anything. Driver's side doesn't do this.
I was thinking it's probably a regulator; does this sound right? If so, should I try to find a good original, or are the reproductions on the market "good" quality?
Thanks!
Travis
D
DusterRT
9
Seattle, WA
Jul 28, 2007
  • Jul 28, 2007
Bump...Buller? Buller?
M
mustangman1974
463
  • Jul 28, 2007
There is a spring in the regulator that should keep the window up. use a compact miror and inspect the backside of the regulator and see if the spring is still intact
R
rob289c
81
  • Jul 28, 2007
On a related note, what type of grease is best for the rollers and tracks? White lithium? I need to clean and lube mine while I still have the inner door panels off.
G
GypsyR
86
SC
Jul 29, 2007
  • Jul 29, 2007
It's actually the spring inside the crank assembly that's broken, you can't see it unless you drill out the rivets holding it to the regulator"scissors".
My 67 did the same thing, difficult to crank up or down and would "fall" down from fully closed.
Two ways to deal with this. First and likely best, places like NPD will sell you an entire new regulator assembly. Don't get just the "scissors" they sell. Though nice, they won't help.
Second, do like I did and just replace the crank assembly. I discovered the crank assembly from a 79-93 Mustang is all but identical. Thes Fox Mustangs have very different window setups though, so you can't use the rest of it. Junkyards are unfortunately only interested in selling the assembly, not just the actual crank part. Happily no one ever seems to want such regulators so they can be had pretty cheap. But being so different they hardly wear the regulator at all, unlike our old heavy windows.
I drilled out the three rivets holding the cranks on and just fastened the Fox Mustang crank to my regulator. After much cleaning, lubing, and some new bushings, my regulators crank the windows up and down with just two fingers and stay wherever I set them too. Worked out so well I did the driver's side too.
Ford has always called for white lithium grease for lube . I haven't found anything better.
D
DusterRT
9
Seattle, WA
Jul 30, 2007
  • Jul 30, 2007
OK, thanks for the confirmation..I appreciate it!!
1989 Passenger side electric window issue
  • Sanchez_005150
  • Jul 17, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2025
WillWho?
W
V
Window rolls down automatically
  • Valicy
  • Apr 30, 2024
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech May 6, 2024
Mustang5L5
W
2012 Base Convertible Driver Side Power Window Will Not Work
  • wmmihail
  • May 25, 2024
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech May 25, 2024
Interior and Upholstery Inside door flex when window rolls up fully
  • beeduckworth
  • Sep 19, 2023
2K
Fox 5.0 Mustang Tech Sep 21, 2023
limp
Y
Resolved 2011 GT Passenger Window issue... weird
  • YFinder
  • Apr 25, 2024
2010 - 2014 Specific Tech Apr 25, 2024
YFinder
Y
