Engine Felpro wire loc headgasket or ?
smarek
Twin Cities MN
I'm getting ready to replace my head gaskets since one has antifreeze leaking out from under the head. I've got the wire locs in it now with TFS 170's on a DSS level 10 306 short block with girdle and 12 psi from a Kenne Bell SC. If there is a better choice for a head gasket I want it, wrenching is fun but driving is better. Any suggestions on head gaskets or other things I can do to avoid leaking head gaskets?
Also, before I tear into it what is the best way to determine if my rings are okay? I have not run a compression check yet but intend to. If I get a low cylinder I'll add oil and recheck to see if the pressure comes up, yes = rings, no = gasket. Are there better methods?
Finally, at the risk of making a multi-thread post, if I go to studs instead of head bolts will I be able to get the heads on and off with the engine in the car? It looks like it will be tight with the brake booster.
I recently found and joined this forum, it is one of the best I've seen, wish I'd found it years and $$'s ago.
