  • SN95 4.6L Mustang Tech
Few Questions
  • Thread starter Thread starter ponysarepretty
  • Start date Start date Oct 4, 2005
ponysarepretty
578
  • Oct 4, 2005
1. For those with Autos... do your cars rev just under 2000 at 65 mph?
2. I hear a creaking sound from the back sometimes, I think it is the brakes or the suspension. Not really sure, is it normal?
3. Today after putting some seafoam in and blowing out the smoke, I broke pretty hard and I smelt some burning smell from one of my brakes, is that normal? It wasn't from inside the engine and it only smelled on one wheel?
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
Oct 4, 2005
  • Oct 4, 2005
How many miles are on the car? Noise from the rear could be a variety of things. Does it happen when you're cruising? Turning? Stopping?
~A.C.
GDawg
1,469
Nevada
Oct 4, 2005
  • Oct 4, 2005
One time I had to slam on the brakes bad. I left myself in a cloud of smoke and I could definitely smell the pads cooking. I even warped my rotors from that. Also, after I Seafoamed my engine it stunk for a day. I had to reset my computer because the "Check Engine" light came on and wouldn't go out until I disconnected the battery for a few minutes.
Just a little fyi...
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Oct 4, 2005
  • Oct 4, 2005
yeah when doing 65mph the rpms are roughly below 2000............ if you braked hard then yes it is normal to get that brake pad smell, and for your noise in the rear it can be quite a few things
BuffaloZone
411
  • Oct 4, 2005
Mine seems to about 2500 at 65mph.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Oct 4, 2005
  • Oct 4, 2005
well that is with the stock gearing (3.27) the rpms are at around 1800 rpm's once you go with 3.73's or 4.10's then the rpms are over the 2000 rpm
ponysarepretty
578
  • Oct 4, 2005
For 1 I meant 3.27 gears, so I think my car has stock gears, although I do hear a little bit of whine, normal?.
I am pretty sure the rear noise is the brakes, normally only occurs when i let go of the brakes from a stop, like at a traffic light, maybe my pads need to be replaced?
My car has 60k miles on it and it has had its 60k service, and I'm pretty sure they checked the suspension in that service... cost me a **** load of money.
These sounds are all very subtle, probably because I took out the back seats...
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Oct 4, 2005
  • Oct 4, 2005
since you took of the rear seats then you will hear more noise inside the car
ponysarepretty
578
  • Oct 4, 2005
Thats what I thought
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
