Few questions..
  • Thread starter Thread starter Guero
  • Start date Start date Oct 24, 2008
Guero
2,148
Oct 24, 2008
  • Oct 24, 2008
Well I already found a 5.0 explorer engine for a 96 for 650 at a junkyard.. The whole thing!!! With 108k miles and good compression.
What kind of cam should I put on it?
Do I use the same timing cover or do I have to take it of the fox?
Should I up the boost or spray a 50 shot?
LiquidGT
368
Near STL hell
Oct 24, 2008
  • Oct 24, 2008
Most people go with the Trick Flow Stage 1 cam and TFS spring kit for those motors.
You'll need the fox timing cover/bolts, timing pointer, water pump, egr spacer/bolts, oil pan, oil filter bung, dipstick, pulleys, hamonic balancer, coolant pipe on intake, valve covers, distributor, and front bracketry to convert an Explorer motor to Mustang. You can transfer all of that from your old fox engine, that's what I did.
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
