Fianl verdict: Mercon V or II/III for AODE?
jaymac
995
Northern Mass
I have to swap the rad., as a bad tranny cooler line connection has been leaking tranny fluid pretty bad (as well as antifreeze!!). When I top off the AODE finally, should I be using Mercon V or the II or III I heard a few people mention?
(aka, what will be best to avoid the "new tranny fluid=death" thing?)
Thanks!
Jeremy
then I would stick with what is in there already (presumably Mercon). As was said, I would not mix the two fluids.
Good luck and bump.
