  • SN95 4.6L Mustang Tech
Finalizing Engine Plans
  • Thread starter Thread starter Performance Red
  • Start date Start date Oct 4, 2005
P
Performance Red
75
  • Oct 4, 2005
Alright I've made a few posts regarding what my setup for the engine i plan to swap in this winter and i just have a few final questions about head/cam selection my currently planned setup was:
MPH Stage 2 1/2 Heads
VT Stage I cams
Dragon Upper Intake Plenum
Dragon 75mm TB
K&N FIPK
BBK Ceramic Coated Longtube Headers
VRS Offroad X-Pipe
4.10's
My plan is to stay n/a with a good amount of performance, but i have a few questions before I start ordering this setup. Would the vt stage II cams be too much cam for a daily driven car? I dont want the car to be really sluggish below 3k rpm. I know the VT stage II's would have a higher peak horsepower number (with the trade-off of having to rev the engine higher to achieve that number), but I'm not really interested in setting the rev limiter any higher then 6,400. I've talked with VT and they say that stage II's are fine in a daily driver, but i still have my concerns. My second question is regarding the 2.5 heads, are they overkill for a n/a car? I have heard that you can reach a point where you have ports that are too large for a n/a car to properly support. Any help is appreciated.
J
jimfitzgerald
6,672
  • Oct 4, 2005
I would order a set of custom Comp cams from MPH and have Tim spec them out to match your MPH heads.
RedDaemon
3,470
9
108
Atlanta, GA
Oct 4, 2005
  • Oct 4, 2005
i think with that custom grind and 4.10's, vt stg II should be fine for a dd
Blown00GTAuto
182
Washington DC
Oct 5, 2005
  • Oct 5, 2005
Performance Red said:
....Would the vt stage II cams be too much cam for a daily driven car? I dont want the car to be really sluggish below 3k rpm. I know the VT stage II's would have a higher peak horsepower number (with the trade-off of having to rev the engine higher to achieve that number), but I'm not really interested in setting the rev limiter any higher then 6,400. ...
If you're going to get "stage 2.5" heads then get cams to match them, i.e, to get optimal performance in your rpm range. As someone already suggested it would be wise to go to MPH for custom grinds. 4.10's will give you more torque to the ground, even though you'll lose some low end engine torque from the bigger cams. Once you feel the top end pull you'll have no regrets.
As far as the ability of a 2v shortblock to withstand a decent level of rpms, my shifting was at 6500 rpms for the longest with 380+ rwhp (on an auto), and I know of 2 others who have shifted stock 2v shortblocks at 6500-6600 for 3+ years of drag racing. One of those cars is 430+ rwhp on a stock longblock - 4 years blown.
billfisher
1,296
huntsville, AL
Oct 5, 2005
  • Oct 5, 2005
2v ports will never be too large.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine 2003 Mach 1 Automatic Upgrades assistance
  • SJK1417M1AT
  • Sep 25, 2025
SN95 4.6L Mustang Tech Dec 21, 2025
01SVTvertt
