Finally finished!!!
  • Thread starter Thread starter Uber88GT
  • Start date Start date Feb 28, 2011
U
Uber88GT
117
Edmonton, Alberta
Feb 28, 2011
  • Feb 28, 2011
I have finally finished my build other than paint...can't wait to get it on the dyno and see what she can do! Anything over 450hp and I'm happy, as long as the block doesn't split...(it's girdled, at least the two halves will be held together!)
Basic info: Stock bottom, girdled with speed pro pistons, ARP everything, RPM heads, novi 1000, meth, 42#ers, LMAF & A9L, tweecer...
So any ideas/observations on what to change? Heads are on my list, but the block is approaching it's limit already...
Thanks!!
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Feb 28, 2011
  • Feb 28, 2011
Looks good! What's the intake setup? Stock hood?
U
Uber88GT
117
Edmonton, Alberta
Feb 28, 2011
  • Feb 28, 2011
The intake is a cleaned-up EFI hurricane (professional chinese products), and it all is under the stock hood, for now. I am on the hunt for a cowl hood to keep things cooler under there....
G
Gunn331
  • Feb 28, 2011
hate to b the bearer of bad news but I've got a dss super pro 331 afr heads custom blower cam trick flow r series upper and lower vortech blower at 12psi and all other goodies and I'm only looking to get 450-475 to the tires
but depending on the boost your running you should get 400 to the tires. the stock bottom end will blow
around the 475-525 range anyways so watch out
but looks good. anything done with suspension and are you having it tuned while on the dyno
U
Uber88GT
117
Edmonton, Alberta
Feb 28, 2011
  • Feb 28, 2011
Not bad news at all, it is what it is! I am looking at about 12 psi also, and have a custom cam for it, and I sure will be getting a tune while on the dyno!
I have koni yellows that are getting coil-overs soon, running the eibach pro kit with eibach sways and cheap upper/lower control arms, but will be swapping them out with MM's when I do the coil-overs..SFC's getting installed next week too
G
Gunn331
  • Feb 28, 2011
thats cool man i went with the lakewood 70/30 up front and 50/50 in the back bbk upper and lower control arms spec stage 2 plus clutch, fully built rear end 8.8 31 spline moser solid rear end 3.73 gear just finished the 4 wheel disc conversion 4 piston calipers. SCT ppiggy backed chip into my A9L should b on the street within the nest 2 weeks. dropping motor in this evening.
G
Gunn331
  • Feb 28, 2011
what size head are you using
U
Uber88GT
117
Edmonton, Alberta
Feb 28, 2011
  • Feb 28, 2011
Just the 170 Performer RPMs with 2.02's...I think they will be my choke point, but not sure if I want to buy some Trickflows or just be happy with what I have...not alot of used heads up here, so new would be the only way to go...
G
Gunn331
  • Feb 28, 2011
thats cool your right if it chokes it will b on those heads. my problem also. should have went 205 but my original project was on a 302. just posted some pics of my project you should check them out
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Feb 28, 2011
#10
  • Feb 28, 2011
  • #10
Dont change anything motor wise, you will just be pissing in the wind cause you will be near the limit of the block. Get it dialed in and then work on the rest of the car surrounding the motor
U
Uber88GT
117
Edmonton, Alberta
Feb 28, 2011
#11
  • Feb 28, 2011
  • #11
That is what the plan is, if a set of heads shows up, great but I want paint next month...and for the block to hold together for the summer!!
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Feb 28, 2011
#12
  • Feb 28, 2011
  • #12
Looks good, do you have fittings welded to the valve covers for the vents?
FWIW I made 544/498 on my stock 93 bottom end, make sure your tune is fat and please get a good balancer on it.(not sure what you have on it)
U
Uber88GT
117
Edmonton, Alberta
Feb 28, 2011
#13
  • Feb 28, 2011
  • #13
The fittings are the Moroso ones here: Moroso 22635 - Moroso Vacuum Pump Fittings - Overview - SummitRacing.com
I did put a "safety wire" tied so if they ever come loose, they won't drop.
As for the balancer, I have a new ford racing one, but was thinking of getting something better, cheap insurance eh.
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
