Finally got my qa1 k-member in with stock arms. PICS added
Ok, first off. Read the instructions all the way through :damnit:
I posted last night about the holes not lining up. Well, With the stock arms you have to grind the back side of the control arms so they fit on the new k-member. Then once you get the space you need you will need to either use the old arm bolts or get a new set of 4 for about $10. The front arm bolts go in just fine it's the back one that are a lil work. You have to grind 1 point off of the bolt head so it will slide in straight. The way the k-member is a whole bolt head wont fit. So if you grind one of the points you can still get an open end wrench on it. Now once you get ready to install the bolts you will see there is some play in the bushing face to the k-member. Just shim each one with a washer and it will be tight. That is what a buddy told me the qa1 tech guy said you have to do with stock arms. I will get some pics up tomorrow night.
Brandon
Brandon
