Roland69 said:I just hooked up my 5 gal air tank and ran a line to my intake and set the regulator at 18 psi and WOW what a ride. Lasts for about 1-2 hours and then I go to the air pump and fill it back up. I have a total of 30 dollars into this and I think I will be in the 10's maby low 11's. I might try to put an A/C compresser on the car and have it fill the tank with a flic of the switch.
bluevenom867 said:I hope you werent serious,casue Ill go shove our 50 gallon compressor in the car right now and max the regulator out....
Roland69 said:I dont know I was just making that up but I have been thinking about that for a while do you think it could actually be done. I want boost but can't afford it and I have a crazy head so that is what this brain thought up.
In the mid 50's for half the year guys were doing something simular to this in drag racing. They had a compressed oxygen bottle in the car with them. it was plumbed into a intake system. they had a switch i guess you call it so that under normal operation the engine was fed normal air. then when drag racing the air inlet was sealed and the oxygen was force fed into the engine. kinda like a prestoric nitrous system. Anyways it was banned because it was way dangerous having a 2400 psi oxygen bottle strapped into the car.Roland69 said:I just hooked up my 5 gal air tank and ran a line to my intake and set the regulator at 18 psi and WOW what a ride. Lasts for about 1-2 hours and then I go to the air pump and fill it back up. I have a total of 30 dollars into this and I think I will be in the 10's maby low 11's. I might try to put an A/C compresser on the car and have it fill the tank with a flic of the switch.
this is done today roland.......... its called Nitrous oxide. unfortunetly it only lasts 100 or so seconds and it isn't free to refill.Roland69 said:I dont know I was just making that up but I have been thinking about that for a while do you think it could actually be done. I want boost but can't afford it and I have a crazy head so that is what this brain thought up.
Sounds good. Post updates with pics for us. I'm especially interested because I pulled a huge rotomaster/garrett t04 60/1.00 for $16 at the local yard. I'm looking to do a single, but have a few pairs of matching turbos set aside too for TT.Jozey said:im finally getting everything together for my turbo.i got a t-4 60mm ptrim for free.cant complain about that.im ordering the rest of the stuff this weekend.i'll post pics when i get everything
I pick up 3-4 of them a wk for under under $80 at my local yard. Then resell them on ebay for usually 4x $$$.Roland69 said:I just hooked up my 5 gal air tank and ran a line to my intake and set the regulator at 18 psi and WOW what a ride. Lasts for about 1-2 hours and then I go to the air pump and fill it back up. I have a total of 30 dollars into this and I think I will be in the 10's maby low 11's. I might try to put an A/C compresser on the car and have it fill the tank with a flic of the switch.
wazazzle said:Sounds good. Post updates with pics for us. I'm especially interested because I pulled a huge rotomaster/garrett t04 60/1.00 for $16 at the local yard. I'm looking to do a single, but have a few pairs of matching turbos set aside too for TT.I pick up 3-4 of them a wk for under under $80 at my local yard. Then resell them on ebay for usually 4x $$$.
it should top out at 450hp or so not as much as i want but it will a fun little turbo.i just orderd my intercooler and stuff.shold have it mid next week
