Finished carpeting my trunk
PJx5x
197
Chicago
well atleast its done until i get the spare tire. a couple months ago i covered the whole thing in wood and i finally started carpeting about 2 weeks ago. it a lil work, but i like the result... anyways here it is. let me know what you think
Great job man!! :nice: :nice: :hail2: How'd you secure the wood at the empty 1/4 panel locations?
Here is mine: I have since completed the rear section. Makes the interior of th ecar alot quiter too
thanks. and actually i used plywood. as for the vertical pieces covering the 1/4 panels, i used some angle aluminum and screwed it down. it moves a lil if you hit it, but its all secure.
Hey Mine's been carpeted for a little while now. Originally it accomodated dual Optima batterys behind each wheel well and as such they were closed in. Since then it has taken a more drag race function, and the stereo and batteries have been replaced as such....
Simple job with some plywood and cheap carpet. Really improved the trunk of the 70. I still fit my entire tool case between the two, and there is room between the backseat to fit a jack if I feel the need.
Ah, so here are some pics i took before and during the wood stages. i dont have any when i was carpetting it. Its all plywood, and the carpet is glued and stapled in the corners.
Edbert said:
MDF would be a good strong material to work with but heavier than particle board which is heavier than plywood. I used fiberboard when I did mine, it is not as rigid or strong but a small fraction of the weight.
Here's a write-up on how I did mine:
http://www.edbert.net/trunk.htm
edbert i never noticed you had one of the super rare and valuable M_stang's before. LOL
