v8only said:I've been working with Joe Fiorentino testing his quadrant and firewall adjuster on my car. He sent me a set to evaluate and comment on for my site
http://50stangs.com/techarticles/clutchcableadjustment.html
I've got tons of pics, if you want to see them.
I was incredibly impressed by his stuff, especially the firewall adjuster. The firewall adjuster has grooves in the thread, in which a ball bearing snaps into them when you twist the adjuster. As well, the clutch cable slides into the firewall adjuster, and slides into a rolling sleeve inside the firewall adjuster. There is no other design like it. What happens, is the rolling sleeve fits around the cable, so you don't have all that damn tension when adjusting it, as it slides very smoothly around the cable.
Joe fiorentino stands behind his product 100%, it's good stuff, and it works great.
ECU5.0 said:i was thinkin about gettin this FWA also. i have the upr one and it seems like it never stays like it should. every time i check it, the stupid thing is loose. guess ill be buying this one shortly...especially since jeremy has some good things to say about it
8950HO said:Hmmm...no other Fiore fans out there?![]()
The guy you mention has an upcoming review on these pieces on his website apparently.
ECU5.0 said:from my experience, if you have a clutch/tranny problem, jeremy (v8only) is the authority to talk to. he has definetly helped me more than once with certain problems. hes a great guy and i wish he was around on this site more often
It seems I've been working for an entire generation to get to 1000 posts here (not that that matters v8only said:Anyone who buys this, and tries it out, let us know how it goes!!!!
fordnatic said:I just installed my Fiore FWA and quadrant yeterday, seems good so far. I replaced my cable at the same time however and I think its about an inch to short. They offer a 59 incher and a 60 incher I installed the 59 and my pedal is super high... and yes the adjuster is all the way in.
