SN65 said:Here is a sketch of the proposed "cage"
We will tie the front of the cage to the torque box area and the rear to the rear suspension mounting points.
Yes, I agree with you on this one. The center section is going to be the weak link.Sicarius428 said:Can I make a suggestion on the framework. The rear and the front looks really rigid and shouldn't have much flex but besides the subframes, there isn't much to keep it from flexing in the middle other than the roofline. Maybe some bars that come out from the roll bar allong the door that attach to the floor similar to an 8 point roll cage. I was just thinking of the inate nature of a flexible chassis is that everything gives a little and with such a rigid front and rear... the middle will be the part that will give. On a good turn with traction to plant the outside tire you will probably end up putting a lot of pressure on the apillars.
Kevin
Yes, the cage is a bit "overkill" but I need something that is both functional and has a certain amount of eye appeal.DukeGnarley said:That rear cage looks cool, but i think it's probably overkill and some of the extra bracing on it will end up being just dead weight.
I am going to have to try and keep this straight. I am hopeing that this type of confusion will fade away when we start to work on the cars themselves.mtbdoc said:Remember: two different cars. The cage is shown for the straightline car. Similar to my 'vert. Not made for the twisties.
It is confusing as he shows the turbo I-6 [for the road course car] in a post next to the caged coupe [1/4 mi car].
Unfortunately, you are correct. I just can't put something in the car that we did not engineer ourselves. My problem is that I am used to designing the supporting structure and platforms for large water tanks and pressure vessels. You tend to go a bit over the top when designing structures located in a seismic zone supporting tens of thousands of pounds.1320stang said:Yeah, I think you're trying to reinvent the wheel with that tube work.
Yes and no.Jester67 said:IMHO, that cage will do no more than keep the roof up in a role over. It will not stiffen up the chassis anymore than good sub-frames.
The structure we are adding to the front end of the car will not interfear with any of the "stock" mustang components.68FBJJZ109 said:The only question i have is will that front cage clear the master cylinder and the hood hinges running through and connecting to the shock towers. I am just curious because i want to tie my shock towers into a roll cage, just i am not at the step.
SN65 said:The structure we are adding to the front end of the car will not interfear with any of the "stock" mustang components.
Look forward to seeing you there.GNN60GT500 said:Hey SN65- not to get off topic for a minute- but Im looking forward to seeing your car for the first time at SEMA...(I work for Magnaflow)
See you there-![]()
I've seen reports of these things doing sub 13 second quarters, stock, in an 1800kg car!
