Firewall Adjuster In!!!! Help Needed Kinda!
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
ok guys got that damn FWA in today.
Put it in
it actually feels like a clutch now and is quite easy like i hear the KC clutches are.
Anyway shortly afterwards, i was sort of flooring it. and shifted hard, and i hear a loud click and the clutch pedal goes all the way to the floor and stays.
I thought something broke. I stopped and stuck my hand down there and the pedal would click back up and work fine...
later on it did it under normal driving, i just normally press the clutch and pop, the stuck to the floor.
in all its happened 4 times.
It didnt do this before i got the FWA.
if it helps i have the stock quadrant
any ideas??
Also whats the best way to accuratly adjust the clutch?
where do i want it to be adjusted with the stock cable???
i'd get rid of that stock quadrant.......although i'm sure you can run a fwa with one there's really no point in it.....i bet your stock one is toast ( quadrant)......i can't think why else it would be stuck to the floor though unless your clutch is adjusted wrong and it's sticking or over extending it self and getting stuck...i bet the stock quadrant is stripped
i agree. i am sure your missing some teeth on the stock quadrant. go with a 1 piece aluminum, quadrant. upr sells nice one with 3 positions. while the cable is out, run some light oil down the tubing and slide cable in and out, between the new quadrant, and the firewall ajuster, and a free cable, your clutch will feel amazing.
yeah also, i don't really think your supposed to use a fwa with out the new quadrant.....
ok see, what happened was, you needed the fwa because you didn't have the stock grommet for the cable to go through on the fire wall....now that you have your fwa, depending on how it's adjusted your stock quadrant doesn't like that and is probably trying to adjust itself and it striped.......you wanna fix that asap because you don't want that quadrant adjusting the cable tighter in conjunction with that fwa because then your clutch might be adjusted too much and you might mess up the cable.....or your quadrant might break altogether and leave you stuck which sounds like it's about on it's way there......
thats why it's taken me so long to get all my conversion to t-5 stuff, alot of little stuff and i didn't wanna deal with it so i'm trying to get every last nut and bolt before i do it....
hmm thats what i was thinking also.
but the quadrant swap seems a little tough with the pedals in the car.
any write ups on them?
also, can i used the stock cable with the aftermarket FWA and quadrant??
yes, thats actually what the fwa was made for......was the stock cable...
as for getting the old quadrant off there.....theres 2 pins it sits on and they have these squirlly clips ( hair pins i believe)that go through holes on the pins, get those pins out and slide and or pry the old one off........the stock one is way more complicated than a new aluminum one......it has a springs and a couple of plastic pieces, don't worry about all that crap just get the old one off......
the new one basically just slides over the existing pins, and you put the clips back in to hold it on, loop on one of the hooks and your good to go........and by the way, different after market quadrants have different numbers of hooks for the cable, some of them 2, some of them 3......doesn't matter which one you get as most people use the middle hook to hook the cable on.....
after market
the stock one- note i don't think that bolt is supposed to be there it accidentally got put in the pic
so if i place the cable on the middle hook i will just have to adjust the FWA out more to make up for the slack??
it looks like if i went to that middle hook it would give the cable more slack compared to the hook on the factory piece...
well thats what the fwa is for but......keep in mind that stock quadrant isn't in a fixed position on the pedal assembly.......see those teeth and that other little plastic piece that locks the teeth in place?? it ratchets......
now lookin at that stock plastic one you can see how they can strip and break the teeth off.....or just slip.....like i said, all that crap will be gone you'll just have the aluminum piece and your fwa
Me and my buddy did my fwa in about 30-45 min right in my garage just moved the seat back and stuffed myself in there. Your quadrant is toast btw. Its like a ratchet now i take it? This happened to mine before the fwa. The plastic gears on the quadrant strip. You need to install the one that came with the kit it will take maybe 15 min 20 min tops.
This stangnet member has a site with a lot of good clutch quad/firewall adjuster info,www.50stangs.com,look under "tech"articles.
cevtv said:
No such thing.............;) Firewall adjuster, yes. Adjustable cable, yes. But no "adjustable" quadrant.
I think the same way you do. However, technically quads with multiple hooks are kinda' adjustable (with regard to their cable hook-up setting).
I, like you, still do a double take when I hear peeps mention that. I suppose the most adjustable quadrant would be the stock quadrant (and pawl). :)
i bought the bbk FWA by itself, i just got some christmas money tonight so. I will buy that double hook quadrant from FRPP.
it did it once today. i was driving and a car was turning into a video store and i wasnt paying attention, so i almost rearended them. I stabbed the clutch hard as i was pressing the brake and and it popped and sunk to the floor.
its hard to say what driving style makes it do it. Its done it when pressed hard and fast, but its also done it under normal driving so...
