HISSIN50 said:If the cable wasnt preloaded, the TOB isnt held against the PP's diaphram fingers. This can allow the TOB to slop around a bit, eating it and the bearing retainer.
The above quote is from another thread.
I just installed my MM clutch quadrant, firewall adjuster and non-adjustable cable yesterday. The instructions for the adjuster said it should be adjusted so there is a little slack when the clutch pedal is not pressed, so as not to wear out the throwout bearing.
But what Hissin50 said above makes it sound like maybe the TOB should be in contact with the fingers on the pressure plate all the time.
Which is the correct way to have the cable adjusted?
Thanks.
Jeff
