71swing said:
yes, the crank will determine the firing order. you can not change the firing order by just changing the cam. It will keep the same fireing order but dapending on the cam specs you may still be able to use it.
Wrong answer.
The crankshaft is the same for plain 5.0's and HO engines. The camshaft determines the firing order. Putting in a HO cam makes a plain 5.0 use the HO firing order.
A V8 crankshaft has to be laid out with the crank throws at 90* to work. Each throw will have an intake, compression, power, and exhaust stroke determined by the camshaft. The relative position of the each pair of camshaft lobes to the other pairs lobes determines the sequence when these events will take place for each cylinder.
Don't forget to use the HO computer, or the engine won't run at full potential.
How to verify that it is indeed an HO engine: remove the #1 & #3 spark plugs. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Slowly turn the engine until the TDC mark and the timing pointer line up. Mark TDC on the balancer with chalk or paint. Put your finger in #3 spark plug hole and crank the engine 90 degrees. You should feel pressure trying to blow past your finger. If you do not feel pressure, repeat the process again. If you feel pressure, it is a HO engine.
No pressure the second time, remove spark plug #5. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Put your finger in #5 spark plug hole and crank the engine 90 degrees. If you feel pressure now, the engine is not a HO model, no matter what it says on the engine.
Using a small carpenter or machinist square to mark the harmonic balancer off into 90 degree sections may be helpful here.
A 15/16 deep socket & breaker bar or ratchet may be used to turn the engine.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
