firing problem
  • Thread starter Thread starter redneckjeff
  • Start date Start date Jul 15, 2007
R
redneckjeff
  • Jul 15, 2007
I have a '69 Mach 1 With a 351W I recently put in a MSD6A ignition box and Pro Billet Dist. I've been through all the tuning advice and through thier (MSD"s) Forum and they can't seem to help me. I'm getting a backfire through the carb.when I punch the throttle. It doesn't change with a timing change but the odd thing I've found is that when I pull any of the plug wires #3, #4, #5, or #7 the idle doesn't change. They are not firing. Now that seems odd to me with them not being on the same plane on the stock intake, and I just rebuilt the Edelbrock carb #1407 750CFM. which is plenty for this engine so It can't be a lean condition. If you can fix this with your advice I'll buy you a beer. I'm that desperate.
D
D.Hearne
11,730
south louisiana
Jul 15, 2007
  • Jul 15, 2007
A carb's cfm rating has absolutely nothing to do with a "lean or rich" condition. If it backfires thru the carb when you punch it, that tells me it is a lean condition. The accellerator pump circuit isn't working correctly. You do not understand how a carb works, get a manual and read up on them. I cannot tell you how to fix the problem as you have an Edelbrock carb (I'm a Holley guy) but the prolem is a lean condition. One of the resident Edelbrock carb guys will have to tell you how to fix it. Come on guys, help him out................
R
redneckjeff
  • Jul 15, 2007
Perhapse you should read the whole post D. Hearne before you start accusing me of not knowing what I am doing. The problem is that 4 cylinders aren't firing. That could be considered lean... You think?????
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 15, 2007
  • Jul 15, 2007
I fixed my Edlebrock by puting a Holly on =-)
Sounds odd.... if those cylinder are not firing I'd check the setings on your box to make sure its set to 8 cylinder mode.
D
D.Hearne
11,730
south louisiana
Jul 16, 2007
  • Jul 16, 2007
NO, if you have 4 cylinders that are not firing, then your motor would be running rich. and dumping the unburned fuel out thru the exhaust. I didn't accuse you of anything. I simply informed you that you obviously didn't understand a carb by your statement that it was overly rich due to the carb being too big for the application.
D
D.Hearne
11,730
south louisiana
Jul 16, 2007
  • Jul 16, 2007
I don't think the ignition would be the problem, he says numbers 3, 7, 4 & 5 aren't firing. If the box was set to 4 cylinder, that wouldn't happen. 3 & 7 fire consecutively as do 4 & 5 . And it would hardly run on 4 cylinders with two sets in the sequence out of the picture.
D
D.Hearne
11,730
south louisiana
Jul 17, 2007
  • Jul 17, 2007
I gather from your silence that I was right and you owe me a beer.................
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 18, 2007
  • Jul 18, 2007
You talking to me or redneckjeff ? If yer talking to me then I owe you more then 1 beer. You ever make it out to California/LA area and I'll take you out for some beers. All the trouble you've saved me/got me out of its the least I could do =-)
D
D.Hearne
11,730
south louisiana
Jul 18, 2007
  • Jul 18, 2007
Naw, I was talking to redneckjeff, he's supiciously silent now about his ignition (carb )problem. I gave it more thought and a backfire will also result from retarded igniton timing but I see that he said he tried adjusting that already. His so called not firing cylinders are caused by the lean condition. It's too easy to check the firing of each, all that's needed there is to check for spark. I think too many guys who are new to carbs think that somehow a carb pumps fuel into the engine like fuel injection, hence the mind thought that bigger is better when it comes to choosing carbs. And also the popular misconception that if one is too big or small, all that's needed it is to "jet it up" or "jet it down" to correct it. Maybe I did come off too strong in my first reply, but his statement that the carb was "more than enough, so it can't be lean", set me off on a tangent. It just showed me that he didn't understand that a carb problem and an ignition problem can make the same end results and can be confused with one another.
Max Power
1,774
St Paul
Jul 19, 2007
#10
  • Jul 19, 2007
  • #10
Maybe they are firing just at the wrong time. Any chance when changing out all these ignition parts that the wrong firing order for the cam was used?
R
redneckjeff
#11
  • Jul 23, 2007
  • #11
Found the problem.
I guess you could say the problem lies with my brother, Who I bought the car from 4 years ago. He never knew that the cam had been replaced with a 302 cam. Even though he owned it for 18 years. He's not mechanically inclined. I switched the firing order and knew as soon as I fired it up that that was the problem... Not a lean condition. So if anyone is getting the beer it would be Max Power. Thank you for your help and if any of you are up here in the Portland OR area I'll buy all of you a beer. Jeff
HookandLadder
261
St Louis
Jul 23, 2007
#12
  • Jul 23, 2007
  • #12
Glad you got it fixed. I was gonna say the firing order was wrong. Went from a 302 to a 351 grind and forgot to reset the order and had the same problem. It'll run....just not in gear or long.
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
J
Car Diagnosis
  • j.2016
  • Aug 31, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 31, 2025
M
  • mnky99
  • Sep 5, 2025
mnky99
M
