first brake job, not sure if i did things right
once you back up the piston on the caliper, there should be enough room for you to slide it back onto the rotor, even with fresh pads on. if the rotors have a lip on them or is glazed (shiny), have them resurfaced. lube the pins, like everyone is saying, replace if necessary.. Good luck
jmd2914 said:
what should i do about the extra room on the passenger side caliper?
Did you hit the brake pedal yet? They should be roomy (LOL) after retracting the piston and installing the new pads. Once you depress the brake pedal, the piston will extend to a normal position. That is, resting against, or very close to, the rotor.
