GRGT1994 said:I believe I saw a tool on Summit Racing (or somewhere else) that helped u pull up all of the lifters without removing the lower intake. You could probably just try your idea, as that's probably effectively the same thing.
Urban96 said:try to get the engine as close to #1 top dead center as possible, easy way is to rotate engine over untill you feel air coming out of the #1 spark plug hole. also the dist rotor should be pointing to the #1 connection
mo_dingo said:If it's 180* away from the #1, turn the crank another 2 turns until you get back to the 10* mark and you should be there.
Scott
yep right near where the stock airbox is/was if you have a CAIblk9450 said:think its by the tfi module on the passenger inner fender. i could be wrong. i miss my 94
blk9450 said:wtf 2 turns would put you back in the same place. one turn of the crank=half on the dizzy
you are right.....sorry about that.
Must sleep........
