I plan on going to the track this weekend...I'm actually off work to do it...but I got a few problems...so help me get there...
First...the car has been driving fine the last two days...and I've tested out the power and it is there now... ...I just wasn't going up high enough in the powerband with traction...at 4k it starts pulling HARD...
Anyways...I'm pulling my car in my backyard (sorry no shop...but good shade) to take the upper intake and valve covers off...etc...to retorque and adjust the valves and as I'm pulling in...I let out of the clutch at to slow of a speed and the car dies...well I try to start it up right after to keep moving and it goes "rrrrrrrr...rrrrrr....rrrrrrrrr" (with each turn of the key)...trying to start but not firing up...so I don't panic (the car was getting hot by that time...it does that at low cruising speeds...fan can't keep up...I'm used to it)...and just waited about 4-5 minutes and while popping the hood and checking everything and go to start it up and it starts right back up like nothing happened?...now what could have caused this...I think it was heat related...????
Okay next I have a bigger header gasket leak than I thought...after the car had shut off and didn't start up...I popped the hood and see exhaust coming out of one of the header flanges where it is supposed to mate up against gasket and head...I bet if I retightened the header bolts it will help that out...because it wasn't that bad a day or two ago...but I didn't tighten them up yet because the heads are still "hot"...I'm going to tighten tomorrow...so in short...is it going to hurt the engine at all running with an header gasket leak...? Oh yeah...today I ordered the FEL-1415 header gasket set but I doubt I'll get them on by this Saturday...
Next...when I go to start up the car at any time...it almost stutter starts and then fires up "officially"?...it will go "vrrmmm....VRRMMMM"...the first one is about 700rpm then it (bigger letters)...jumps to 1800 rpm within a 1/2 second of each other atleast...any ideas?...
Also...when I took off my upper intake plate (right side)...a little amount of oil was in the intake coming through the pvc hose I believe...there was a little puddle of it...what can stop this?...what does it mean?
I hope I made sense with these observations so you all can help me out...
David
David
