First Engine Rebuild, Part Reccomendations?
  • Thread starter Thread starter TRIBUNAL
  • Start date Start date Aug 5, 2016
T
TRIBUNAL
103
Aug 5, 2016
  • Aug 5, 2016
So I recently made a post about my engine being seized. ( http://www.stangnet.com/mustang-forums/threads/sat-now-seized-engine-advice.891870/ ) It was rust in the cylinders and it looks like it wont take much more than a basic hone to clear things up. The connecting rod bearings all looked great and so does the crank. I haven't taken the cam out yet.
Like I said in the title I haven't done this before, I watched my father do it when I was a kid but mostly I am watching YouTube vids and getting help on here to get this far. I assume the best option is to remove everything and replace all the bearings because how much more effort would it really take. So assuming that's a good plan, what do I order?
I looked on summit for a kit and options were limited. I came up with 205-6345M000 or 2056214M-000
Both brands are sealed power
Is this junk? Maybe it would be better to order the parts separately and order better parts?
Someone in the last post I made recommended Kings Bearings.
The engine is stock, I may pick up some GT40 Iron heads if I have the cash, or possibly in the future, but I never plan to make it a 400hp track car or anything like that.
You guys have really helped me out and I appreciate it, thanks for any help you can provide.
Reactions: Davedacarpainter
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Aug 5, 2016
  • Aug 5, 2016
Hey was following your thread.
my budget build consisted of The Sealed Power Hyperutectic Pistons with stock cast iron style rings, Kings Bearings [ we use these in all our racecars ] stock crank, stock rods, block taken out to .03 over [makes it a 306] and a good balance on all the parts.
take the block to have it cleaned and machined at a local reputable shop, they will tell you if it needs to be bored. If it does order the pistons in the necessary size with matching rings. I would suggest you have them size all your bearings for you that way you get what you need to do it right.
Sealed power stuff has held up in a few of our Nitrous motors very well, and my blower motor.
Reactions: stykthyn and A5literMan
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Aug 5, 2016
  • Aug 5, 2016
You'll also need a bunch of incidentals. For example complete overhaul gasket kit,oil pump and pickup,cam bearings,new balancer(don't reuse the stock one),water pump(no reason to reuse an old one),timing chain(and why not a new cam while you're in there),new head bolts/studs,and misc extras I'm forgetting.
The sealed power parts are fine for most modest builds. Like a91what stated above just make sure you get a decent shop to check out the block,crank,rods etc. They need to make sure the rotating assembly is sized correctly(if the crank-Rods need to be resized and order the correct bearings). If you're assembling yourself just make sure you keep the work area clean. Use lint free rags,plenty of assembly lube,etc and have a good manual to set all the tolerances correctly.
Reactions: Davedacarpainter and a91what
T
TRIBUNAL
103
Aug 5, 2016
  • Aug 5, 2016
Thanks, Forgot to mention that it's a 91 ho block.
Yea figured on most of that.
You really think the whole assembly needs to be checked? It didn't have any issues before getting the rust.
What type of rings you guys recommend?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Aug 5, 2016
  • Aug 5, 2016
yes check it all. iron ductile rings [stock] will work just fine. Moly rings will require a much finer hone.
Reactions: A5literMan
T
TRIBUNAL
103
Aug 6, 2016
  • Aug 6, 2016
saw this on a site:
OEM Iron rings: 180 or 240 grit
Chrome rings: 240 or 320 grit
Moly Rings: 320 or 400 grit
Plasma Rings: 320 or 400 grit
not sure ring type: 240 grit
RaggedGT
Mod Dude
Jul 20, 2014
4,766
3,224
203
Taylorsville ky
Aug 6, 2016
  • Aug 6, 2016
https://lmr.com/item/LRS-6009E/79-9...-Short-Block?gclid=CI39pYS2rc4CFQgKaQodhz0O8g
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Aug 6, 2016
  • Aug 6, 2016
Why spend twice the money of the diy route? It has cast pistons = junk. Hyper are the way to go on a budget they can still hold boost.
T
TRIBUNAL
103
Aug 6, 2016
  • Aug 6, 2016
yea im not spending $1500.thx though.. Wondering what all this is gonna cost i am considering if a junk yard motor would be a better way to go...
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Aug 6, 2016
#10
  • Aug 6, 2016
  • #10
Go yank the whole engine from a explorer 5.0. Most of the budget upgrades are done at that point. You get the better heads and the intake can be resold on ebay for 200$
T
TRIBUNAL
103
Aug 6, 2016
#11
  • Aug 6, 2016
  • #11
So my concern then is this. How long has it sat? Could there be rusty cylinders in that engine too? I guess I would prefer anything under 80k miles which I have had a hard time finding looking on craigslist...
I was considering this already in case there were bigger issued with my engine, but now seeing we're already talking easily over $500 I am guessing as I haven't called a machine shop yet... plus The heads should probably be checked as they're pretty dirty...
I really hate making decisions... I guess my next step is to talk to s&k speed shop not too far from me for some pricing and see what I am looking at. then see what a used engine would cost me... Maybe I can find someone selling a rebuilt 302 short block. I did see a guy selling one reasonable that was a 306... hmmm
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Aug 6, 2016
#12
  • Aug 6, 2016
  • #12
If you are really that tight on money hone the one cylinder, re ring the piston, and put it back together. this will get it going, its not the right way but it will work. a simple hone is cheap watch a video on how to do it correctly then wash the block and cylinder out with hot soapy water.
T
TRIBUNAL
103
Aug 6, 2016
#13
  • Aug 6, 2016
  • #13
Well If I do it the right way and get the parts for $250-300, assuming I can reuse the big stuff. and I do the hone myself with a flex hone 240 or 320 grit, what do you think a machine shop would charge for all that other work that was recommended?
I don't mind spending total 500 or maybe 700 to do it all the right way but when we get beyond that I have a hard time justifying it when I can probably find one done for less. Maybe I am imagining the machine shop as being more that it would be.
stykthyn
5,232
2,652
223
gainesville
Aug 6, 2016
#14
  • Aug 6, 2016
  • #14
At this point you are going to need a master gasket set and new rings. I'd budget 400 just to get what you have buttoned up and running. You can have an explorer engine for that kind of cash.
RaggedGT
Mod Dude
Jul 20, 2014
4,766
3,224
203
Taylorsville ky
Aug 6, 2016
#15
  • Aug 6, 2016
  • #15
the last ford motor I went through cost me around 1K with the machine shop dipping and honing the block,and it was basically stock when it was done,figured for a couple hundred more it would be the same but with a warranty. My bad man
T
TRIBUNAL
103
Aug 6, 2016
#16
  • Aug 6, 2016
  • #16
Ok I think that's what I will do..
So I'll try to find one with good miles that has the gt40 non p's if I can or get the gt40p head engine and buy the expensive headers if need be..
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Aug 6, 2016
#17
  • Aug 6, 2016
  • #17
mac shorty headers usually fit with little issue on the p heads. they also make a "header plug" its short and will fit nicely with almost any header with a stockish build they will work just fine.
T
TRIBUNAL
103
Aug 6, 2016
#18
  • Aug 6, 2016
  • #18
thanks a lot man I'll look into that.
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
Cleaning up Aluminum
  • limp
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2026
KRUISR
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
