First Mods To Do?
  • Thread starter Thread starter Quijibow_69
  • Start date Start date May 1, 2004
Q
Quijibow_69
44
Mechanicsburg, PA
May 1, 2004
  • May 1, 2004
I was wondering what the first mods are that I should do. I have an '89 Mustang GT. I'm buying it with shorty BBK Headers, BBK H-Pipe (not sure if off road or not), and Flowmasters (not sure what series).
I was wondering what my next mods are to do. I was thinking intake, throttle body, and then I'm stumped. What do you guys suggest, and what are the best brands out there?
Thanks!
85GTlover
704
  • May 1, 2004
Get full sub frame connectors, not for speed but good for your car. Worry about others later. Cheap and stiffen your car greatly.
Sir Hacksalot
363
Ankeny, IA
May 1, 2004
  • May 1, 2004
Subframes, gears, exhaust, UD pulleys, Electric Fan, Pro 5.0 shifter.
Hax
T
tom2001gt
292
Delran N.J.
May 1, 2004
  • May 1, 2004
I would get gears first and subframe connecters. I put subframe connecters on my car the other day and my car was bent pretty bad.
BillaMustang
491
  • May 2, 2004
hi, do you have emissions testing where you live ? if so, you will need to take that into consideration.
M
Matts89LX5.0
1,314
Long Island, NY
May 2, 2004
  • May 2, 2004
get gears and then suframe connectors. Enjoy the world of mods with mustangs
T
tistan2
128
  • May 2, 2004
Get a intake, underdrive pulleys, cold air intake, and bump up your timing. You will pick up 20-25 rwhp for about $600-800.
Z
zeusmoto
390
utah
May 2, 2004
  • May 2, 2004
i would agree slap some gears into the stang. and some subframes.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
May 2, 2004
  • May 2, 2004
First would be gears without a doubt. Second would be subframe connecters. Third would be a complete exhaust setup from the headers back. If you're new to 5.0s and especially if you're new to V8s, you've got plenty of power to get used to, and just these mods will let a stock 5.0 show it's true colors. After those, i'd start on the suspension. Get some nice lowering springs, new shocks/struts, caster/camber plates for the front, upper and lower control arms for the rear. After all that, even with a stock motor and trans, your car will kick some ass.
My car has a bone stock motor with 250k+ miles on it. Sure it's nothing to brag about speed wise, but every person i've raced was really surprised that the motor is as stock as it is, and i've still got a stock suspension.
Power can only do what power does when it's got a good suspension to work through.
T
tistan2
128
#10
  • May 2, 2004
  • #10
If you are going to do gears then you mine as well do axles and a good tractoin locker. It is pointless to pay someone $300 to install gears then have to go back and pay the same $300 to do the traction locker when most shops will charge $300 to install everything at once. Any mustang you buy with over 80k miles is on the verge of a traction locker failure.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
