first start motor troubles...
  • Thread starter Thread starter stprorolla49
  • Start date Start date Sep 3, 2006
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
Sep 3, 2006
  • Sep 3, 2006
hey guys, this is a question about a carburated small block chevy, but i figure ill ask here because its most likely going to be a generic answer to my question...my dad and i just rebuilt a 350 sbc to put in his chevelle...its like the 5th time hes built a motor, so all the tolerences are spot on, the valvetrain is quadruple checked clearence wise (rockers and whatnot), we have the fuel pressure set correctly and we are definately getting fuel to the carb because we flooded it twice and had 3 small carb fires....we even tried a different carb we had from the previous motor which we knew worked, and it didnt make a difference...
we primed the oil pump to 40 psi for about 2 mintues, we set TDC 3 times, then advanced the balancer to 4 degrees below TDC...we set the dizzy perfectly to the Number 1 plug, all the wires are on correctly, firing order has been triple checked, the plugs are all good, all the wires are getting spark, and everything seems like it should fire right up...
IT WON'T!! and we can figure out what the hell is wrong! the starter turns the motor fine, but it doesnt even so much as sputter at all like its going to start! we thought maybe the battery was a bit undercharged so we hooked jumper cables up to my dads durango, and fired it, and still nothing...at this point, we spent 7 hrs trying to figure out the problem, and we havent been able to....at this point my dad is getting very frustrated, and i really wanna help him out...i spent all day out there today with him just like i always do, and as much as i LOVE to work on the cars, its just very discouraging...
as i said, this is probably a generic answer, so if you have ANY advice, please post up...thanks a million:SNSign:
if this helps, heres the setup...
350 small block, canfield iron torquer heads, comp cams alum roller rockers, comp cams cam (about 480 lift) ,edelbrock performer intake, holley 650 DP carb, hooker long tubes, 3 inch exhaust, MSD 6al ignition box, MSD pro billet dizzy, MSD blaster coil, etc etc
stprorolla49
1,455
15
39
Sep 3, 2006
  • Sep 3, 2006
ttt
bill302
2,131
alabama,gadsden
Sep 3, 2006
  • Sep 3, 2006
pull the #1 plug place finger over sparkplug hole sealing the hole,have an assistant turn motor by hand while sealing the #1 sparkplug hole with your finger when you feel pressure blowing your finger off the hole insert a screwdriver carefully into the sparkplug hole turning motor until piston reaches top (which will be indicated by the screwdriver) which is called top dead center at this point look at the rotor it should be pointing toward where the #1 sparkplug is located on the distributor cap....if it is not you or he should know what to do...
bill302
2,131
alabama,gadsden
Sep 3, 2006
  • Sep 3, 2006
this might help too.click on link... also a compression test could be helpful...
http://boxwrench.net/specs/chevy_sb.htm
stprorolla49
1,455
15
39
Sep 3, 2006
  • Sep 3, 2006
thanks bill good info...were gonna give that a shot tomorrow
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Sep 3, 2006
  • Sep 3, 2006
Dude, I had the exact same issue with starting mine after the trans swap. I was 100% sure my timing was set right and the dizzy rotor was pointing to the #1 plug at TDC. Spent an entire day troubleshooting everything. I finally decided to just mess with the dizzy again and turned out that it was about 90* off. Car fired right up.
It may be worth it to just rotate the dizzy to the next tooth and see what that does.
stprorolla49
1,455
15
39
Sep 3, 2006
  • Sep 3, 2006
thanks bud...if this works, ill buy you a 6 next time ur here!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 4, 2006
  • Sep 4, 2006
The following is for a 5.0 carb'd engine , but the only difference is the fuse links & firing order.
Cranks Ok but no start for carb’d cars.
Updated 4-Sep-2006
Carb'd cars require an old time approach to troubleshooting.
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw with the red wire to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B. ) Distributor PIP sensor or points & condenser
C.) No power to ignition system wiring or ignition box (if used)
D.) Bad ignition switch
E.) Bad fuse links.
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model Mustangs
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
4.) Pull the air cleaner and sniff for fuel vapor - look for signs of flooding. If so, then press the accelerator to the floor and crank for a while – if the engine is flooded, this will clear it out. You may want to have a jumper battery & cables handy.
5.) Electric fuel pump if you have one, is it getting power? Use a volt meter or test light to probe the wires at the pump.
Don't see any evidence of flooding? Then pump the throttle - does the accelerator pump squirt fuel? If so then you should have enough fuel to start the engine. If not look for fuel delivery problems. Check the fuel pump, and fuel filter. Remember that most carbs have a fuel inlet filter that protects the float needle valve from trash.
Next, get a can of starting fluid (ether) from your local auto parts store: costs a $1.30 or so. Then pull the air cleaner, open the throttle, and spray the ether in it. Reinstall the air cleaner and try to start the car. Do not try to start the car without recinstalling the air cleaner. If it backfires, the chance for a serious fire is increased. If the engine starts now, you have a fuel delivery problem.
A warning about backfires: Holley carbs may have damaged power valves as the result of a backfire. The engine may be hard to start. Other symptoms are that it may seem to load up on fuel and be slow to accelerate until it clears out a bit.
6.) Fuel & ignition OK:
Firing order off: HO & 351 use a different firing order from the non HO engines.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
Check to verify that it is indeed an HO engine. Remove the #1 & #3 spark plugs. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Slowly turn the engine until the TDC mark and the timing pointer line up. Mark TDC on the balancer with chalk or paint. Put your finger in #3 spark plug hole and crank the engine 90 degrees. You should feel pressure trying to blow past your finger. If you do not feel pressure, repeat the process again. If you feel pressure, it is a HO engine.
No pressure the second time, remove spark plug #5. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Put your finger in #5 spark plug hole and crank the engine 90 degrees. If you feel pressure now, the engine is not a HO model, no matter what it says on the engine.
Using a small carpenter or machinist square to mark the harmonic balancer off into 90 degree sections may be helpful here.
A 15/16 deep socket & breaker bar or ratchet may be used to turn the engine.
stprorolla49
1,455
15
39
Sep 4, 2006
  • Sep 4, 2006
great info man...you always come through!
R
R2D2
Sep 4, 2006
#10
  • Sep 4, 2006
  • #10
carb fire = 90-180 degrees off
bill302
2,131
alabama,gadsden
Sep 5, 2006
#11
  • Sep 5, 2006
  • #11
whats the verdict...
stprorolla49
1,455
15
39
Sep 5, 2006
#12
  • Sep 5, 2006
  • #12
when we depressed the clutch for the first time the other day, obviously the clip that holds the fork was a piece of garbage, because it broke right off...so we need to drop the tranny and fix that before we can try and start the motor...the last thing we need is shards of clutch coming thru the floor into my leg...
D
d.s.s 306x
27
Elma wa
Sep 5, 2006
#13
  • Sep 5, 2006
  • #13
you can always hook up a timeing light(you don't need the motor running to do this) just hook it up normal and turn dizzy back and forth ,if its in time the light will flash
good luck
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
J
  • JRC99
  • Apr 19, 2025
2K
JRC99
J
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
